Thread: Oil pan bolts leaking
Reply to Thread
Results 1 to 19 of 19
  1. #1
    Join Date
    Oct 2000
    Bath, Somerset, UK
    Default Oil pan bolts leaking
    Last year I fitted up a bigger oil pan and with new gasket. Been getting a little oil leak when hot, traced it to a couple of the oil pan bolts. No gasket leak at all. I put thread-lock on all the pan bolts, did finger tight, then torqued in sequence from middle out (and double checked!) when I fitted that new pan. I wonder if I removed the offending bolts, and refit now with a copper washer, maybe that will sort things? Any like experiences or advice?
  2. #2
    Join Date
    Apr 2001
    South Salem, NY USA
    Default Re: Oil pan bolts leaking
    Hi Nadine,
    A copper washer is a good idea, you could try a dab of silicone in the bolt hole should do it.
    BBQ 45 days and counting!
    Scrumpy?
  3. #3
    Join Date
    Feb 2002
    Buffalo NY, USA
    I had this same issue on my car after installing a Pan-Baffle system. Cure was:
    1. Remove pan and gasket
    2. Clean all bolts, and bolt holes in pan/block with Q-Tips and alcohol/Laquer thinner-(quick dry)/Acetone/Etc.
    3. Wipe both pan and block surfaces with an above cleaner, making sure any sealers-such as whats used on the 4 corners-is gone.
    4. Wash oil pan gasket with Dish-Soap and WARM water to cut all oil from it. allow to air dry...may help along with cotton towel-(but wipe fibers off when done)
    5. Check entire gasket for flat spots, missing peices, etc. and replace if necessary.
    6. purchase some Red, high temp RTV silicon sealer, and 4 6" or longer 1/4-20 bolts.
    7. place a small drop of RTV on each corner of engine block, where front and rear covers contact block...then spread this drop out thinly in a 1"x1" square.
    8. thread the 4 6"+ bolts into pan corners, and allow pan and gasket to hang suspended on the heads of the bolts.
    9. AGAIN, make sure Block surface is 100% free of oil drops!
    10. Raise pan on 4 Bolt "Guides", and install pan bolts. Tourque bolts from center out, 95 Inch Pounds.
    (the guides serve to help keep the RTV on the corners from smearing durring the typical "slide-around" install)
    If leaking persists after this,you have either a porous block, porous/warped pan, or a bad gasket.
  4. #4
    Gateway
    Ron's Avatar
    Join Date
    Oct 2000
    Indianapolis
    Do the oil rail bolt holes actually penetrate into the inside of the block?
  5. #5
    Join Date
    Dec 2000
    Roswell, Georgia
    Mine do too. In fact some tech stripped a couple so they fell out ! Helicoil and sealing is probably only realsitic solution. Fairly common issue actually. I just put a shallow dish under each leaking bolt and then recyle the oil back into the oil fill. ;^ )
  6. #6
    Join Date
    Aug 2001
    Los Altos, CA
    Daniel (Final GTS), holy cow are you thorough! An inspiration to us all!!!
    For my 0.02,I had similar leak on valve cover, from the bolts only, no where else. I used short cuts
    compared to Daniel (shame on me), removed the offending 2 bolts, washed em with dish soap and warm
    water, thorough dry, dabbed some Mopar (from my friendly Viper Tech, talk about service!) RTV on either
    side of the bolt threads, re-installed and torque to proper spec...Even though I obviously did not give
    the threaded holes the proper cleaning, the "fix" worked like a charm.
    Tomer
  7. #7
    Join Date
    Feb 2002
    Buffalo NY, USA
    NADINE- no, the holes to NOT penatrate into the block cavity.
  8. #8
    Join Date
    Jun 2001
    Western New York, USA
    Dan,
    is the man!
    I have him on retainer as my personal Vipertech!!!
    Next year Dan when my viper will be home for the winter, I think we can add your
    kickass oil pan!!
    All this talk about your oil system has me thinking it is something i should do!
  9. #9
    Join Date
    Oct 2000
    Bath, Somerset, UK
    Yep, a few of mine do penetrate through into the block!! Select few about the main bearing cross bolt points.
    The problem is then that where the bolt head / washer seats, against the pan, is not machined flat, it's rough, straight from the casting!
    For now, I'm giving it a try with fresh Lock-tight on the thread, OE washers cut off, and replaced with washers I got from a hydraulics company today, they are steel with a silicon rubber center part (like the oil pan drain plug washer). I don't think it will work though, as the washer won't sit central to the bolt hole due to the closeness to the curve shape of the pan. I will probably end up getting them machined flat (same angle as the pan gasket face).
  10. #10
    Join Date
    Feb 2002
    Buffalo NY, USA
    NADINE- how did some of your bolt holes get poked into the cavity??? I suggest if worse comes to worse on those, assuming enough room, seal them up with loctite and a small grub scew, or put a bunch of Red RTV in the hole and squeeze it up into position with the screw, clean off excess where it flows out of top, allow it to dry, and remove screw. (would have to be done with Pan OFF)
  11. #11
    Join Date
    Oct 2000
    Bath, Somerset, UK
    I may actually try a cutting tool that fits in a drill (Joel's idea) that seats square in the pan hole, and machine flat that way the pan bolt seat points. ...I'm being lazy, coz I spent ages cleaning and perfectly sealing that new pan gasket (as you say, it can be sliding around job, but I perfected it much as you describe).
  12. #12
    Appears that I'm in the oil pan bolt hole leaking club. I have one bolt toward the front of the motor, drivers side that is leaking. Looks like a very old thread, any updates or changes I should be aware of before
    attempting a fix? I have an '02 Viper GTS.
  13. #13
    Gateway
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    R T V is a popular "fix"...removing the pan bolts one at a time, cleaning bolt, applying a dab of RTV, installing bolt...then on to the next bolt. Yes it is time consuming but worth trying. Some might use the anaerobic type of R. T. V.
    I don't do "PM's" and I NEVER read "visitor messages" since I prefer DIRECT communication.
  14. #14
    Northeast
    Join Date
    Aug 2007
    Western MD
    I see this TSB >> 09-08-97 NOV 97 Engine - Oil Pan Seepage.
    But does not have a link on viperclub.org ? Anyone have a copy of TSB for Viper?
    1997 GTS Red
  15. #15
    International Viper Registry Curator
    Join Date
    Sep 2010
    Idaho
    “Success is not final, failure is not fatal: it is the courage to continue that counts.”
    ― Winston Churchill
  16. #16
    For me to remove, clean, reinstall, etc the bolt and RTV does the motor need to be completely cooled down? I need to take the car in town (a few miles) to get it on a lift to do this. Can this be done when the motor and fluids are warm/operating temperature?
  17. #17
    Northeast
    Join Date
    Aug 2007
    Western MD
    There is no link for "09-08-97 NOV 97 Engine - Oil Pan Seepage" just the text.
    1997 GTS Red
  18. #18
    Northeast
    Join Date
    Aug 2007
    Western MD
    Quote Originally Posted by Steve-Indy View Post
    Steve-Indy, while I was looking up/learning about anaerobic red RTV I found this >> Permatex® PermaShield™ Fuel Resistant Gasket Dressing & Flange Sealant
    https://www.permatex.com/products/ga...lange-sealant/
    1997 GTS Red
  19. #19
    Gateway
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    I think you find that the anaerobic is required for the dipstick tube sealent.
  1. Oil Pan Bolts
    By 94RT10VIPER in forum RT/10 and GTS Discussions
    Last Post: 06-26-2006, 09:23 PM
  2. Torque on coolant plugs, hood bolts and paint on intake bolts?
    By 95Viper in forum RT/10 and GTS Discussions
    Last Post: 06-08-2005, 03:32 PM
  3. Oil Leak....still leaking....still leaking.....
    By Stiffler in forum RT/10 and GTS Discussions
    Last Post: 05-09-2002, 02:38 PM
  4. Something leaking
    By paul in forum RT/10 and GTS Discussions
    Last Post: 10-20-2001, 09:38 AM
  5. leaking car
    By Ron in forum RT/10 and GTS Discussions
    Last Post: 10-19-2001, 04:36 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
