Thread: Any haul their Viper on a Uhaul car trailer?
Reply to Thread
Results 1 to 5 of 5
  1. #1
    Join Date
    May 2002
    Glen Allen, Va
    Default Any haul their Viper on a Uhaul car trailer?
    May have to travel a ways to have my Roe S/C installed. Anyone ever haul their Viper on a rented Uhaul car trailer. My brother collects antique corvettes and used one once with no problems. However, I would assume that a 67 corvette is not as low and as wide as the Viper. Any thoughts would be appreciated.
  2. #2
    Join Date
    Nov 2000
    NE Ohio
    Default Re: Any haul their Viper on a Uhaul car trailer?
    It is a nightmare trying to get the car in place without tearing either the dam or the sills behind the front wheel. I don't know if all the U-Haul's are the same, however, you might want to find a trailer specialty dealer. Another problem could be the inability to open the doors due to the high trailer fenders.
  3. #3
    Join Date
    Oct 2002
    Tampa Fl. USA
    If by some miracle you are able to get it on the trailer without damaging something,you will have to climb out the window as the door will not open against the wheel wells on the trailer.Then you will have to figure how to roll up the windows .DEFINETLY not worth the aggravation and damage that you will be more than likely to incure
  4. #4
    Join Date
    Dec 2001
    Morgan Hill
    I towed my car 400 miles in the rain (not recommended) on a U-Haul trailer. It was so tight that I had to slowly wench it up into place, and the side sills were uncomfortably close to the wheel rail skirting. It was the cheapest way to move the Viper, but I'll likely never do it again.
    -Dean.
  5. #5
    Join Date
    Feb 2002
    Novi, Michigan
    I did it as well, my Uhaul store had a trailer with the side rails lower than the doors, so I could get out. A bit scary, but not impossible. Had to use long 2x10 board to drive up without bottoming out front bumper (trailer tilted down and back), and used strips of rubber between tires and trailer sides to prevent movement, then latched it up on all for corners as tight as my strength would allow.
    However, when discussing my accomplishment with the uhaul trailer at a Viper club meeting, several people said "You should have called, I would have let you borrow mine". That would be my first step next time. Try it.
  1. Just received my Featherlite Trailer to haul Gen 3
    By ZDigital1 in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 04-02-2007, 12:31 PM
  2. Are you interested in a Perfect (open) trailer to haul your Viper?
    By Double Venom in forum Sneaky Pete's Place
    Last Post: 03-31-2002, 11:46 AM
  3. Does "UHAUL" have a trailer where I can transport a Viper?
    By JBS99HT in forum Sneaky Pete's Place
    Last Post: 01-02-2002, 08:22 PM
  4. Does "UHAUL" have a trailer where I can transport a Viper?
    By JBS99HT in forum RT/10 and GTS Discussions
    Last Post: 12-31-2001, 05:26 PM
  5. Will my '00 RT fit on a U haul car trailer?
    By SoCal Rebell in forum RT/10 and GTS Discussions
    Last Post: 12-20-2001, 07:52 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
