Thread: Calling all ROE SC Vipers
Reply to Thread
Results 1 to 8 of 8
  1. #1
    Join Date
    Mar 2001
    Pomona, NY
    Default Calling all ROE SC Vipers
    I'm wondering what other mods you did while installing Roe SC. Did anybody do 1.7 rockers, gears, headers...
  2. #2
    SUN RA KAT
    Guest
    Default Re: Calling all ROE SC Vipers
    Stock rockers, stock gears, VEC2, S&B filters with 70 mm smooth tubes, Roe 70 mm air box, 70 mm throttle bodies, Belanger Headers, Randon Tech Ultra high Flow Cats, Corsa 3" Cat Back, Roe fan timer, lightweight flywheel, MGW shift knob, Woodhouse modified shifter, & Roe Supercharger #35.
    436 rear wheel HP & 480 Torque before Roe Supercharger. See below signature for dyno measurements before the new & improved VEC2.
  3. #3
    Join Date
    Mar 2001
    Pomona, NY
    Great numbers! I dynoed 437 and 480 too!
  4. #4
    Join Date
    Jan 2002
    Plymouth N.H. USA
    Roe Supercharger #17 stock rockers-1.7s would not just bolt on without headwork 70mm throttle bodies 70 mm smooth tubes vipermed airbox b & b headers random high flow cats 3 inch corsa cat back system delrin suspension bushings eradispeed rotors ebc pads stainless steel brakelines msd wires march billit pulleys heavy duty half shafts
  5. #5
    Midsouth
    fuelman's Avatar
    Join Date
    Jan 2003
    Lake Mary, Florida USA
    I did the T&D 1.7, but I did them before the Roe Supercharger. My car is 2001 and the rockers made a big difference, the car went 11.97 at 120 mph. I have a Corsa, no cats, and stock exhaust manifolds. Car runs strong, at V-10 Nationals on drag radials I went 11.13 at 127 mph with the 5 lb charger. I would go with the rockers before headers. I think it is one of the mods that Sean recommends for the super charger.
  6. #6
    Join Date
    Oct 2002
    Ny
    oh uh, I'm dead meat
  7. #7
    Join Date
    Mar 2001
    Pomona, NY
    Fuelman: I was told that 1.7 rockers don't fit the SC setup. Did you get the adjustable?
  8. #8
    Join Date
    Oct 2002
    Winter Springs, FL, USA
    ElDiablo, I have the Roe SC and the 1.7 RR..........Macedo installed it with no problems............I also have TNT Headers, Borla exhaust, 70mmTBs, no cats.
  1. Calling All 'Real' Vipers -- Not The Fake Ones
    By gallaugher in forum RT/10 and GTS Discussions
    Last Post: 01-24-2006, 10:00 PM
  2. PA VIPERS... ST 125 CALLING....
    By RedEnuf93 in forum VCA Viper Events and Gatherings
    Last Post: 05-23-2005, 09:13 PM
  3. Calling all Black Vipers
    By ZX1100 in forum RT/10 and GTS Discussions
    Last Post: 06-23-2002, 11:32 PM
  4. Calling all SAN DIEGO Vipers!
    By 2charmed in forum RT/10 and GTS Discussions
    Last Post: 09-29-2001, 12:40 AM
  5. LE-MANS...CALLING ALL VIPERS
    By in forum RT/10 and GTS Discussions
    Last Post: 12-31-1969, 07:00 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
