Thread: Tire repair
Reply to Thread
Results 1 to 3 of 3
  1. #1
    Join Date
    Aug 2002
    Carlsbad, CA
    Age
    68
    Default Tire repair
    What is the general consensus on having a Michelin Pilot Sport repaired? Pulled a screw out of a back tire this afternoon, took it to my "tire guy" and had it plugged. Hole was in the tire tread face between the raised sections of the tread. He did what he called a "high speed" tire repair. Should I be worried about the tire at speed?
  2. #2
    Join Date
    Nov 2000
    LA, California
    Default Re: Tire repair
    I had one in one of my pilots since about 1k on the car, and never had any sort of problem. Had the car to 150 or so on numerous times, which thinking back might have been pushing it. But the patch held, although many would recomend buying another tire if you are planning on severe speeds.
  3. #3
    Join Date
    May 2003
    Socal
    Just spend a couple hundie and replace the tire. Maximum performance tires should not be repaired/plugged IMHO. If you're doing any track days, drag racing, or high speed cruising, do you really want to risk your viper or maybe your life because a tire shreds. No thanks.
    just my two c's
  1. Viper Tire Repair in North/Central FL?
    By viperbob in forum General Viper Discussion
    Last Post: 04-13-2007, 03:02 PM
  2. Tire repair or not to, or just buy a new one??
    By Scott5ppg in forum RT/10 and GTS Discussions
    Last Post: 01-27-2007, 07:43 PM
  3. Tire repair in N. Tampa, FL area
    By viperdude118 in forum RT/10 and GTS Discussions
    Last Post: 08-29-2006, 10:15 PM
  4. Welcome to the Tire Rack sponsored Wheel, Tire, Brake and Suspension Forum
    By Jay Herbert in forum Tire , Wheel, Brake and Suspension
    Last Post: 01-21-2006, 12:05 AM
  5. Has anyone here had to repair a rear tire (nail hole etc..) ?
    By TAPROOT in forum RT/10 and GTS Discussions
    Last Post: 05-08-2002, 10:41 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
