Thread: 2000 GTS, born 8-2000, good date?
Reply to Thread
Results 1 to 13 of 13
  1. #1
    Join Date
    Aug 2003
    Cincinnati, OH
    Default 2000 GTS, born 8-2000, good date?
    Have a steele grey 2000 GTS born 8-2000. Have heard of some issues with some 2000 GTS's. Any problems with one built around this time? What kind of cylinders does it have?
  2. #2
    SUN RA KAT
    Guest
    Default Re: 2000 GTS, born 8-2000, good date?
    Q - Any problems with one built around this time?
    A - Not until you drive it.
    Q - What kind of cylinders does it have?
    A - Round and ten of them.
  3. #3
    Join Date
    Aug 2003
    Cincinnati, OH
    SUN RA KAT....Now that is useful information! Thanks
  4. #4
    Join Date
    Aug 2000
    Vancouver, WA
    Cast Pistons / and approx the 1st 200 or so had issues. Yours appears to be a later build date. Not all the info you need, but more than Sun Rat Cat.
  5. #5
    Join Date
    Jul 2003
    Raleigh,NC
    Mines runs great
  6. #6
    Great Lakes
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    Recall 999.
  7. #7
    Join Date
    Apr 2001
    langhorne, PA USA
    KGRIF, 2000gts built until 11/99 have a problem with piston sleeves. Not sure of all specifics. Mine was sent out to Arrow for a rebuild. I was buring excessive amounts of oil at track..1-2 qts per session. Also had sparkplug
    fouling problem. Your build date should be fine.
    Fast Eddie
  8. #8
    Join Date
    Sep 2002
    Richardson, TX
    Kenny, c'mon now...you gotta be serious on this side of the pond!
  9. #9
    Join Date
    Apr 2003
    Las Vegas, NV
    kgrif - your build date is too new to have the cylinder sleeve problem. VIPORXXX is right about the dates. My understanding of the issue is that they tried powdered metal cylinder sleeves in the first 200 cars of '00 but that material is so hard (much harder than the sleeves they were using before) that it prevents the rings from seating properly quite a bit of the time. This leads to excessive oil consumption as VIPORXXX mentioned. My engine is currently at Arrow for a rebuild for this exact reason - I had gone through 4 quarts of oil in 1600 miles of normal street use.
  10. #10
    Join Date
    Oct 2001
    Windsor,Ontario,Canada
    MY black Viper GTS was born on 11/99; no oil issues and a strong motor. MoparMan my VIN is 1B3ER69E2YV602816; I'm curious as to how close your Viper was built to mine?
  11. #11
    Join Date
    Aug 2002
    Houston, TX , USA
    Kenny, LMAO! That was a good one!
    Andy
  12. #12
    Join Date
    Apr 2003
    Las Vegas, NV
    My car was built 10/11/99 and the VIN ends in 705. I don't know if the VINs are in sequence or not, but if they are my GTS was 111 cars earlier than yours. Interestingly, I've heard of a couple other black/silver '00s with this problem. My understanding is that not all of the cars with the powdered metal cylinder sleeves have the problems with the rings not seating properly. Obviously, all of the test mules they built had no problems...
  13. #13
    Join Date
    Oct 2000
    Mission Hills, Ca USA
    Good luck
  1. Born on date for tires?
    By Silver Snake in forum RT/10 and GTS Discussions
    Last Post: 10-04-2005, 06:42 PM
  2. 2000 GTS GOOD PRICE?
    By Larz in forum RT/10 and GTS Discussions
    Last Post: 10-06-2004, 12:04 AM
  3. 2000 OEM WHEELS/TIRES FOR SALE.........$2000
    By VIPERCANE in forum RT/10 and GTS Discussions
    Last Post: 07-07-2004, 06:14 PM
  4. My Viper's Born On Date
    By SUN RA KAT in forum RT/10 and GTS Discussions
    Last Post: 02-09-2003, 08:19 PM
  5. ACR Shock Upgrade Pre-2000 or post-2000???
    By 99 Sidewinder in forum Performance Modifications
    Last Post: 03-06-2002, 03:30 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
