Thread: My door won't latch
Reply to Thread
Results 1 to 8 of 8
  1. #1
    Join Date
    Oct 2000
    Motor City
    Default My door won\'t latch
    When I close my door it bounces off the latch and won't close. Then if I pull it again it seems like the latch works and it closes. I've repeated this a few times and each time the first try it just bounces and the second time it will close.
    Is it the solenoid going bad? Or do I just need to shoot some lube?
  2. #2
    Join Date
    Apr 2001
    South Salem, NY USA
    Default Re: My door won\'t latch
    Bounces off the latch? Hitting the latch? Not closing all the way? If so you may have to adjust the door up a little. They tend to settle or drop with age. "Just like a lot of things"
  3. #3
    Join Date
    Nov 2003
    Queens, New York
    Age
    44
    i have the same problem and its hitting against my wheather stripping...door is off the hinges and needs to be adjust upwards. can be done by unscrewing the three screws from the body panel between the door and hood. remove it and you will see the hinges that hold up the hoor have someone hold the door a bit upwards and tighten the screws again and see if that works. actually a thread on this is you do a search.
  4. #4
    Join Date
    Oct 2000
    Motor City
    That's what I thought at first. But it latches on the second try. When it does latch I'm not lifting on the door or slamming it harder.
  5. #5
    Join Date
    Oct 2000
    Toronto Ontario, Canada
  6. #6
    Join Date
    Oct 2000
    Motor City
    do they make one that matches Viper red???
  7. #7
    Join Date
    Apr 2004
    NORTH STAR DODGE VIPER TECH, S.A. TX
    hm...i think i see red in that pile of colors!!!...lol..
  8. #8
    Join Date
    Sep 2001
    windsor, ontario, canada
    exact same problem on my 97 driver's door, to the point I gently close it until the popper "pops" then reopen and shut normally.
    if the door closes on the 2nd time with the same pressure and seals normally it is most likely an electrical issue, ie. the popper is in the closed position when it should be open, and not a fittment issue I would think?
    been like that for a while on mine, on occasion it's a three or four attempt try, bothersome to say the least.
    let me know if you solve it, and I'll do the same!
  1. Door latch
    By PaViper in forum RT/10 and GTS Discussions
    Last Post: 03-29-2012, 08:21 PM
  2. Door Latch
    By Canyon707 in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 06-03-2007, 09:56 PM
  3. Driver's Door Won't Latch
    By Vintage Racer in forum RT/10 and GTS Discussions
    Last Post: 10-27-2005, 01:18 PM
  4. Gen I Door Lock Latch
    By 99 R/T 10 in forum RT/10 and GTS Discussions
    Last Post: 03-30-2002, 12:34 AM
  5. Door latch problem
    By Chuck 98 RT/10 in forum RT/10 and GTS Discussions
    Last Post: 08-29-2001, 09:47 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
