Thread: Roe supercharger
Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 30 of 31
  1. #1
    Join Date
    Feb 2004
    Cottage Grove, Wis.
    Default Roe supercharger
    As some of you know from previuos posts from me, I have been contemplating getting a Roe blower. After making a lot of phone calls, I think I have decided to bite the bullet and buy one for my Gen1 94 RT/10. I would like to hear from those of you that have a Roe blower and tell me the good and the bad. I know Sean is a top notch person and will stand behind his work. Have you had any problems? Tuning issues? Anything at all would be helpful. I plan on placing my order eithet Weds. or Thurs. after I hear from those of you that have a blower. Thanx!!
  2. #2
    Join Date
    Sep 2003
    Xenia, Ohio
    Default Re: Roe supercharger
    Wise choice, I ordered mine last week. Cant wait.
  3. #3
    Join Date
    Aug 2003
    Cincinnati, Ohio
    Now, correct me if I am wrong here. According to Sean, this charger would put down 520 ( maybe more? ) RWHP right away. This is with an complete stock engine ( other then blower of course ). The RWTQ is around that much.
  4. #4
    Join Date
    Aug 2003
    Jacksonville,FL.
    To give you guys an idea. When mine was on my 2002 GTS w/no cats, B&B catback, 70mm t.b.'s,3" smooth tubes,3" air box mod,filters,MSD plug wires,aluminum flywheel it put out:
    Run #1 525 rwhp/ 550 rwtq
    Run #2 526 rwhp/ 546 rwtq
    The car had been sitting cold for hours and idled for about 5 mins. before Run #1 started. After heat soak sets in the SOTP feel is less.
  5. #5
    Join Date
    Sep 2003
    western wisc.
    If I get one, are YOU guys gonna give me a place to live????
    <smiley gettin' kicked in the nutz>
  6. #6
    Join Date
    Oct 2002
    North Carolina
    Your numbers seem kinda low. I have the same mods.except I also have T&D Rockers. My car is also an 02. After 8 dynos, waiting 15-30 minutes apart, heat soaked, low 90's outside, with terrible humidity my best was 581 rwhp and 596 rwtq.Sae corrected. This was before any of the upgrades we're available for the vec2. I now have the updates and some very fine tuning from Larry Macedo. I would be curious to see what my new numbers would be. When we dynoed my car was barely broke in. It only had 1600 miles.
    We differ on brand of modifications I use Balenger Headers, Random Hi-flow cats the metal ones, and Corsa exhaust. I wonder if one combo works better than another or just different dynos???????
  7. #7
    Join Date
    Aug 2003
    Jacksonville,FL.
    [Your numbers seem kinda low.]
    2MANYTOYS
    Yea I thought so too. I was told my car was probably a weak 2002 from the factory. But now I have no s/c and I did add 1.7 RR & Belanger headers. Larry Macedo did the s/c removal and install on new parts. My dyno #'s using his same dyno now are:
    471 rwhp/498 rwtq w/o a s/c
    Dynoed right after s/c removal w/o new parts So everyhting was equal. My #'s were:
    443 rwhp/ 483 rwtq
    I lost 83 rwhp/ 67 rwtq when the s/c was removed.
    So I don't think my car is weak at all. Larry is installing NOS/Propane for me now. Can't wait to fill that jolt.
  8. #8
    Join Date
    Oct 2002
    North Carolina
    2MANYTOYS
    Yea I thought so too. I was told my car was probably a weak 2002 from the factory. But now I now have no s/c and I did add 1.7 RR & Belanger headers. Larry Macedo did the s/c removal and install on new parts. My dyno #'s using his same dyno now are:
    443 rwhp/ 483 rwtq
    I wonder if my car having the headers and Rockers made the difference in HP & TQ?
    I bet that is the case. If you did not have the rockers or headers when you had the S/C that sounds like a possible difference of 40+/- hp which would have put your car in the same range as mine.
    I don't buy other peoples theories that some 02 were slow from the factory. Those are good numbers with the bolt ons you have now.
    You gotta love Macedo. He's great with the cars.
  9. #9
    Join Date
    Feb 2004
    Cottage Grove, Wis.
    It sounds like there aren't to many many complaints about Roe's blower. I was told by Sean that for a Gen1 viper I could expect a 35-40% increase in HP and TQ. So that would put me around 500-525rwhp. The only mods I have are are high flow cats and mufflers and smooth tubes. Should I or shouldn't I.................I think I shall!
  10. #10
    Join Date
    Oct 2002
    North Carolina
    I'd go for it you won't be disappointed.
  11. #11
    SUN RA KAT
    Guest
    I love my Roe S/C - it makes the Viper a much better car.
  12. #12
    Join Date
    Jan 2002
    Plymouth N.H. USA
    I LOVE MY ROE S/C MORE. JUST LOOK AT MY AVATAR IT IS BEAUTIFUL. ALSO THE 664 RWHP AND 694 RWTQ ALSO MAKES ME SMILE ALOT.
  13. #13
    Join Date
    Jan 2003
    Reno, NV, USA
    My only complaint is the change that comes over your car, it is no longer just a Sunday cruising car, driving in town at 25-30mph is a chore, you have to wait for the car ahead of you at the light to get far enough ahead so you don’t pull right up on their bumper when you very gingerly apply the throttle. Your friends egg you into childish burnouts. The car scares your wife and makes your sister scream like little girl when you barely even get on it and haven't even broken 90mph. Your onramp near your house becomes a ¼ track, and if you have a chance for a good pull up the on ramp you will make the people behind you honk their horns and cuss you out while you let the other cars that have entered the on ramp get ahead so you can blast up the ramp. Friends ask you questions like, "what are you trying to do turn this thing into a top fuel dragster…”
  14. #14
    Join Date
    Feb 2004
    NY/CT
    Age
    33
    35-40% with what pully??
    if its a 5 thats more then you get on a gen 2 on a gen 2 its 25-30% with a 5 pound
  15. #15
    Join Date
    Feb 2004
    Cottage Grove, Wis.
    He said a 5# pulley! That is amazing, all that HP and TQ by just adding a blower. When I do get this thing installed, I will lose my extended warranty on my motor, that is the only thing I dread. I talked to my dealer this a.m. and he said I would lose my coverage. Oh well, I will get over it.
  16. #16
    Join Date
    Apr 2004
    Chicago, IL.
    Call some other dealers, read, read, read! Don't let them kill your warranty. A year from now you'll hear "Too bad you didn't take your car to XYZ Dodge, they are super viper friendly. "
  17. #17
    Join Date
    Apr 2004
    Chicago, IL.
    IEATVETS,
    You have a PM.
  18. #18
    Join Date
    Feb 2004
    Cottage Grove, Wis.
    Thanx for the PM Matt, I am calling tomorrow to check into that. Chicago isn't to far away either, only about 1 1/2 hrs. Hope it goes well, cause I want to be blown!! The car that is.
  19. #19
    Join Date
    Jun 2001
    Utah
    I think I might have one of the fastest roe sc'ers and I am happy with the blower kit. You cannot beat it for the price/performance. I was one of the pioneers of the heads/cam roe sc'ers and had my share of problems but it was just because I was one of the early guys. I currently have no problems with my drivability and performance. Sean is also excellent to work with.
    I am a little afraid of the gen1 heads/cam blower cars because I think they will make more power than a gen2 with the same mods. Good luck to the gen1 guys with their new found power.
    BTW, I think I have tapped the maximum potential of the roe supercharger. TO be able to run 148.6 MPH in the 1/4 with a roe blower @12psi is simply incredible. You also have guys like 1tony1 and cudaman running 144+ mph. This a statement of the potential of the blower.
  20. #20
    Join Date
    Jan 2002
    There is a problem with the roe s/c , a real problem i was hiding it since long time now and its time to say it
    you need sticky tires
    perfect setup easy to install i installed it my self and i have a friend with a 99 rt/10 he did the installation alone too, we both have zero mechanic experience, but the way sean wrote the manual and the support sean gives, is more than you need.
    As a matter of fact i ended up having two roe s/c's vipers, now what this tells you.
    Go for it my friend, let the power of boost be with you. ciao
    Utahviper, 148.6 MPH congrats man this is insane, almost like turbo viper's or even faster, any guess RWHP/RWTQ numbers ? i belive less than the turbo cars !! Awesome really awesome!
  21. #21
    Join Date
    Jun 2001
    Utah
    MBN
    I am sure I have less HP/TQ than you. You need to get yours to the track and lay down over 150MPH trap speed. I don't have any dyno numbers but I would guess around 775-800RWHP and 825-875RWTQ. I don't think I could accomplish that trap speed with less HP/TQ.
  22. #22
    Midsouth
    fuelman's Avatar
    Join Date
    Jan 2003
    Lake Mary, Florida USA
    I just had some warranty work done today on the ABS system, no questions. The car is so streetable, and so fast. 5th gear on the highway is a blast, at 70 mph just blink and your at 120 mph. This is a great all around system, it was 85-90 F today, stuck in traffic the car runs the same as a stock Viper. Again, as many people have said each Viper is different, I think the dyno tunning is a must. Go for it!!!!!!!
  23. #23
    Join Date
    Feb 2004
    NY/CT
    Age
    33
    Mbnviper what else do you have done to this car
    02 FE GTS ROE S/C 903 RWHP & 1090 RWTQ ?
  24. #24
    Join Date
    Mar 2002
    Miami, FL--> SLITHRN, USA
    2MANYTOYS
    443 rwhp/ 483 rwtq
    Mike, isnt it funny that the so call expert told you anything he could, to get you to accept the low HP numbers that kit puts out. I am glad Larry was able to dismiss that false claim also.
    RIP: www.floridavipers.com McQuire shut the site down because one post did fit Roe's Agenda, just sad and pathetic.
  25. #25
    Join Date
    Feb 2003
    Panama
    What times (in the 1/4) can a Viper with 525rwhp and 550 rwtq do?
  26. #26
    Join Date
    Aug 2003
    Jacksonville,FL.
    Well I was disappointed in my dyno #'s but I wonder if I would have given Larry a chance to do his magic on my car w/ the s/c if he couldn't have sucked out better #'s. Anyway, I'll try the NOS/Propane for awhile and hopefully that will give me the HP #'s I want. As far as Roe Racing is concerned I have no hard feelings about my dyno #'s and still plan on doing business w/ Sean in the future.
    As far as the ex-www.floridavipers.com go I'm hearing different versions of the REAL story. I'll stay out of it since it doesn't really concern me.
  27. #27
    Join Date
    Jun 2001
    Enterprise, AL USA
    That's too bad! I like to go over to that site to talk to you guys. Giong to miss it.
  28. #28
    Join Date
    Aug 2003
    Jacksonville,FL.
    Mike
    We are over at V10nationals.com now in a N. Fl. section if you wanna join in. Maybe www.floridavipers.com will be back soon.
  29. #29
    Join Date
    Mar 2002
    All the North Florida Stuff will be here from now on: New North Florida Vipers Site.
    v10nationals.com, go to north florida section.
    Mike, Smart move, dont believe everything you hear, you obviously dont have a weak motor from dodge as you were told, so why would anything else be different.
  30. #30
    Midsouth
    fuelman's Avatar
    Join Date
    Jan 2003
    Alvaspeed, my car intially made about 525/560, when I first had the SC installed, no headers with cats etc. On Drag Radials it was good for low to mid 11's at about 122-123 mph.
  1. Supercharger
    By LIRacer in forum RT/10 and GTS Discussions
    Last Post: 01-17-2010, 07:40 AM
  2. Where else to buy a Roe supercharger ?
    By X vetter in forum RT/10 and GTS Discussions
    Last Post: 06-15-2006, 11:16 PM
  3. Roe supercharger
    By MadMaxx in forum RT/10 and GTS Discussions
    Last Post: 07-01-2002, 06:42 AM
  4. The best looking supercharger I've ever seen.....
    By 2thDr in forum Sneaky Pete's Place
    Last Post: 12-20-2001, 10:46 PM
  5. Supercharger
    By Chuck 98 RT/10 in forum Performance Modifications
    Last Post: 11-18-2001, 03:32 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
