Thread: cat delete - I found the cheapest way possible to do this
Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 30 of 51
  1. #1
    Join Date
    Oct 2000
    Atlanta, GA 30319
    Default cat delete - I found the cheapest way possible to do this
    So I was going to have a muffler shop cut me some 3" pipe for my cat-delete project... but since I'm cutting out high-flow cats, I might want to put them back on...
    So I headed to autozone just to see what they have.
    3" pipe, 18" - 5 bucks. I bought two.
    Two clamps - 10 bucks each.
    Total cost for exhaust parts - $30.
    And it looks great.
    If the pipe rusts, for $10 I can replace them.
    JD
  2. #2
    Join Date
    Aug 2003
    Cincinnati, Ohio
    Default Re: cat delete - I found the cheapest way possible to do this
    Why only two clamps? Wouldn't you need two for each pipe? Or does the GTS have only one cat? I thought the RT/10 had two ( obvious reasoning. )
  3. #3
    Join Date
    Dec 2003
    FL
    Age
    58
    I would like to do that too, but does'nt the computer try to run the engine super rich without the cats??
    Has anyone gotten the check engine light on the dash after the cat delete?
  4. #4
    Join Date
    Oct 2000
    Atlanta, GA 30319
    I only needed 2 clamps b/c I had 2 that were used previously from the headers to the cats. For someone with a system welded all the way through, you'd need 4 clamps.
    As for the 02s, you need 02 sims to keep the computer codes from coming on... RoeRacing sells them... those are the ones I'm using.
    JD
  5. #5
    Join Date
    Dec 2003
    FL
    Age
    58
    where do you install the O2 sims and how much are they?
    Thanks for the good info!
  6. #6
    Join Date
    Oct 2000
    Atlanta, GA 30319
    O2 Sims I got from a local VCA member who was going to hi-flow cats. New you can get them from roeracing.com .
    The way they install is quite simple... remove your stock O2 sensors. Cut the wires between the harness and the sensor. Then splic the 4 wires from the 02 sims to the wiring harness. Then put them back on the car and tie-wrap them and / or tape them out of the way. You'll also want to get a "plug" for the hole from the 02 sensors since these will be empty. The plugs were $2 each and threaded perfectly.
    I'll be at the dyno this weekend so I'll post results on the difference between between the WITH cats and W/O hi-flow cats...
    JD
  7. #7
    Join Date
    Dec 2003
    FL
    Age
    58
    Thanks JD,
    think I will do that soon!!
  8. #8
    Join Date
    Oct 2000
    Atlanta, GA 30319
    Oh yeah... you only need 02 sims on 98 and newer cars... methinks.
    JD
  9. #9
    Join Date
    Dec 2003
    FL
    Age
    58
    SWEET!!! mine is a 97......are you sure?
    Thanks again,
    Ted
  10. #10
    Join Date
    Nov 2001
    MI
    Casper Electronics sells plug-in rear sims for about $125
  11. #11
    Midsouth
    Chuck 98 RT/10's Avatar
    Join Date
    Oct 2000
    tampa, fl USA
    Plug in would be a better fix than splicing. Got a pic?
  12. #12
    Join Date
    Nov 2002
    Atlanta, GA
    I was VERY amazed at how the pipes looked! It was Sunday, so all the muffler shops were closed. I remember seeing pipes at Autozone, but these fit PERFECTLY.
    JD - You shouldn't have posted this. We could have sold a cat-delete kit for $100
    Oh, and as a reference. The O2 bung hole plugs are 18mm x 1.5
    You can get them at muffler shops... should be around $2 each.
  13. #13
    Join Date
    Oct 2000
    Atlanta, GA 30319
    Default Re: cat delete - PICS!
    Someone asked me about how well this sucker seals... so here are all the parts you need to have. Note that the pieces in between the NAPA part are both 3" pipes... the left side of my Autozone pipe was built to receive a 3" pipe... evne better!
  14. #14
    Join Date
    Aug 2003
    Cincinnati, Ohio
    Damn..!!! That actually looks like a " shop or factory " type mod. Very well done man...
  15. #15
    Join Date
    Oct 2000
    Atlanta, GA 30319
    Thanks! I couldn't have done it w/o Linh (Achilles99) who'd done it the hard way before.
    Suffice to say, the tricks are as follows:
    a - get that NAPA clamp
    b - under that clamp, put tin foil
    c - in the middle of the tin foil, put a bead of muffler repair / sealant. It compresses out, but will form a nice seal inside.
    d - torque the clamp bolts to 90 ft lbs
    That's it. Makes for an easy install!
    JD
  16. #16
    Join Date
    Feb 2004
    Germany, NRW, Ge
    Any chance on getting soundfiles up?
  17. #17
    Join Date
    Mar 2004
    Boston Ma.
    What does this do to emissions testing. Mass is very strict about removal and even replacing of Cats? Will the car pass an emissions test?
  18. #18
    Join Date
    Nov 2002
    Atlanta, GA
    Yes, I was amazed at how well this came out! I recently did the opposite (removed straight pipes, put in high flow cats) with ChrisGTS' help (until 4am, I might add!), and we found out a few tricks that helped JD and I with his install.
    To add to JD's tips, we put the sealant underneath the foil, and then "pasted" the foil around the pipe joint. Then, we put the clamp on top of that. The exhaust paste dries rock hard. The clamps seal pretty tightly, but with almost 900 rwhp, better to be safe than sorry Oh, and the clamps are 60-75 ft lbs, which come out 90 newton meters, wasn't it JD?
    The flared pipe from Autozone was built for a Viper cat delete, but only if you have 3" pipe coming from the header. On mine, I had to use a reducer.
    As for the sound... it's GREAT!
  19. #19
    Join Date
    Nov 2002
    Atlanta, GA
    Emissions will be fine since we added O2 sims. It's hard to see the cats on a Viper without removing the sidesills... does Mass. do that on your Viper?
  20. #20
    Join Date
    Nov 2000
    Atlanta Ga
    The mass standards are the same as here in metro atlanta, The sims trick the OBD @ into thinking the cats are there, You will be surprised how clean the car can be, In Ga on OBD cars if the check engine lite is on you will fail automaticly, hence the sims. On non obd cars the sniffer & rolling road is used so you may fail on the early cars if the cats are off. On my Ferrari, when I lived in mass it always failed...untill I ripped all the usa smog stuff off & installed the euro set up ( no cats) & keep it tuned it passed with flying colors.
  21. #21
    Stang7900
    Guest
    I was told by ROE Racing today, that you do not need O2 sims on a 99, and to save my money. Only 2000 and up. Can anybody verify this for me?
    I will be cutting out my stock cats next week. Do you think it will be louder than an aftermarket cat back borla. BTW- I have the snake oyl muffler delete pipe installed
  22. #22
    Join Date
    Oct 2000
    Atlanta, GA 30319
    I needed them on my 99... JD
  23. #23
    Join Date
    Jun 2003
    Kenilworth, IL
    No cats and a cat-back with no muffler? Nah, that won't be loud!
  24. #24
    Join Date
    Apr 2004
    White Marsh, Maryland
    I have a 97 GTS and removed my cats last November. I used the same Autozone supplies. The check engine light never appeared and the car is 15 degrees cooler inside now. Not to mention the sound is awsome. I got a waiver in MD for emissions becuase my car cannot get over the rollers to be hooked up to the OBD port
  25. #25
    Join Date
    Oct 2000
    Atlanta, GA 30319
    BTW- borla w/ no cats isn't that loud at all.
    Here is the pic that was originally in this post a long time ago...
  26. #26
    Join Date
    Nov 2000
    When I was young and dumb, I busted out the cat's mono-lith with a hammer and a rod. Thats the quickest, cheapest cat delete you can do.
    Uh, until you need to pass smog, then you gotta buy another cat. Then it becomes the most expensive cat delete method.
    I don't wanna talk about it!
  27. #27
    Join Date
    Apr 2004
    NORTH STAR DODGE VIPER TECH, S.A. TX
    on 99 cars it can set the check engine lite on..it matter if it was a late build or an early build....from my findings so far....Len
  28. #28
    Join Date
    Oct 2003
    TX / AZ / CA
    That might be fine for Gen 2's, but the Borla 3" mufflers with the 3" high flow cats (from S.Roe) are loud as all hell on a Gen 1, when you are sitting just above your exhaust outlets. I like the car to be loud, but this setup is TOO dayum loud.
    I wonder how much louder it will be if I do a cat delete?
    Otherwise, I may end up having to do something completely different. Any suggestions?
  29. #29
    Join Date
    Nov 2004
    Joseph: So you have had this setup for a year, right? Any problems so far? Have you had to adjust anything (like rattling pipes)?
    Very impressive. This looks like something I can do on my own.
    By the way, you should be able to use a spark plug to block an O2 bung. I used an old spark plug base on my Mustang, and it threaded right in. I just busted the porcelain part of it out and screwed it right in. It'll save ya a couple bucks.
  30. #30
    Join Date
    Oct 2000
    Atlanta, GA 30319
    I've been running this for about a year, yah. no issues. no rattling... passed emissions...
    O2 bung is _almost_ the same as a spark-plug... talk to ViperRich or 1tony1 about that...
    Joseph
  1. Where to buy extended warranty/cheapest
    By Larry in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 06-09-2006, 12:36 PM
  2. cheapest shipping freight company???
    By venomblue550 in forum RT/10 and GTS Discussions
    Last Post: 01-12-2006, 12:07 AM
  3. cheapest srt-10 viper in canada??
    By SRTRICKY in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 01-12-2005, 11:50 PM
  4. WHO IS THE BEST AND CHEAPEST TRANSPORTER TO HAVE RT SHIPPED..
    By RED 97 GTS in forum RT/10 and GTS Discussions
    Last Post: 02-22-2003, 10:19 PM
  5. Cheapest viper for sale....
    By Jason-Middle Tennessee in forum Archive Management
    Last Post: 03-28-2001, 06:41 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
