First time Viper owner
smfettig
Livermore, CA
Hello all,
I have finally achieved my dream of owning a viper. I recently purchased a 1994 RT-10 with 18K miles. I have visited this board as an observer for the past 5 years in hopes of someday owning one of these beauties. The time has finally come, however I have a few questions and was hoping someone could help.
1) How much oil consumption is normal?
2) I have the slight smell of rubber coming from the passenger side front wheel after my weekend drives. I know the tire isn't rubbing, but was wondering if the bearing needs to be greased? Anyone else run into this?
3) Any of you have trouble with flat spots on the Michelin's? I have one flat spot on the front driverside tire, but none on any of the others. The original owner claims all tires are original. When I say flat spot I mean its flat. I can't see how someone could have skidded out and caused this. Has anyone else encountered this??
4) Lastly, sometimes I hear a very slight pulsating whine when I make a sharp turn from a dead stop. It sounds to me like a ;) sound generated from a pulley. I'm not sure though. Any reoccurring pulley problems?
Thats all the questions I dare to ask at any one time. I feel like a proud parent who only wants the best for his baby.
Thanks in advance
Steve
Yves
Atlanta, GA
Welcome and congrats on your purchase !
Some quick replies on some of your questions :
1] I hardly have any on my 94.
3] If your tires are originals, dump them ASAP. Those things are dangerous (should be rock hard after all these years). Buy Michelin Pilot Sports or Kuhmos.
4] Check steering fluid. Even dropping slightly below the minimum line can cause grinding.
PaViper
Welcome and congratulations,
1. Chuck says from a little to a quart per 1000 miles is OK
2. I would have it checked for sure.
3. Get rid of the original tires ASAP.
4. If you steer all the way to the lock, I would think that a little whine or pulsing would be normal
Now get out and put some miles on it :headbang:
MaxedGTS
Ohio
welcome and get rid of the original tires.They will kill you. Enjoy your car.
Max
scottgf
Southern California. USA
Welcome aboard!!!
I have had my 94 since 99, got it with 17k miles...now it has over 40k miles.
Only problems:
1 set front pads/rotors
p/s hose
and done for preventative reasons before ext warr expired
fuel pump
p/s pump
head gaskets
It has been one of the most reliable cars I have owned...
Like Max said...lose those old hard tires and go out and drive the sheit out of it :)
BTW..94 Vipers are well known for being the fastest... :)
especially if its red....
Cheers,
Lennatave
