Thread: Installing oil temperature sensor
Reply to Thread
Results 1 to 3 of 3
  1. #1
    Join Date
    Apr 2004
    Canada
    Default Installing oil temperature sensor
    I want to install an oil temperature sensor.
    I was wondering where is the best place to install the sensor.
    (oil pan or somewhere else ?)
  2. #2
    Join Date
    Oct 2000
    Wappingers Falls
    Default Re: Installing oil temperature sensor
    I put mine in the oil pan above the drain plug; the casting is thickest there and it's still under fluid level. (Gen 1) Also, it's the bulk oil temperature; the value that most use when trading oil temperature information.
    Don't know for sure, but often these is a threaded plug in the oil filter adapter assemby to close off where the oil passages were drilled. If you can unscrew the plug and install the pressure pick up there, that would measure oil temp just before or after the filter.
    While the oil cooler lines are accessible, you wouldn't see any temps until oil ran through it (when the thermostat opened.) And on the return side, it'd be cooler than what's in the engine. Also, it would be in a pressurized location and another place to risk a leak.
  3. #3
    Join Date
    Apr 2004
    Canada
    Thanks !
  1. Battery Temperature Sensor and Optima Battery
    By VNMOUS in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 08-23-2006, 12:06 PM
  2. 0158 Code (O2 Sensor Circuit High Voltage) Bank 2 Sensor 2
    By onerareviper in forum RT/10 and GTS Discussions
    Last Post: 07-02-2006, 10:37 PM
  3. Installing oil temperature sensor
    By Schulmann in forum RT/10 and GTS Discussions
    Last Post: 12-13-2004, 08:51 PM
  4. temperature guage
    By dave1123 in forum RT/10 and GTS Discussions
    Last Post: 05-01-2004, 04:29 PM
  5. OIL TEMPERATURE?
    By ViperGTS in forum RT/10 and GTS Discussions
    Last Post: 06-26-2002, 07:28 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
