Here's my dash:
Not a very technically demanding job, but it takes a lot of elbow grease to prep the old dash. SOS pads, fine sandpaper, etc. Someone mentioned a paint stripper to strip off the old gray stuff, but I wasnt able to find anything. Powertools, ie dremel also dont work and cause gouges. Take your time and have plenty of cold 12 oz. beverages handy. I just used plain old Krylon primer and satin black with satin clear coat. Painted the bezels Viper Red with paint from paintscratch.
From another post by OBAA96 re a product to help strip off the old gunk:
"I posted about using the paint stripper. I used Easy-Lift-Off (ELO) from Polly S; I got it from a hobby store. It's used to strip paint from models without harming the plastic underneath; you should be able to find some equivalent at a good hobby store. The original coating is pretty nasty stuff, because it melts into a gummy goo. I basically applied the stripper, covered it with some plastic wrap (the stripper flashes off quickly otherwise), and used a small scraper to remove the bulk of the coating. Then re-applied and took the rest off. Finally a third coat to remove the final bits. Its a major PITA, but a lot easier than sanding (which I tried first), plus I didn't damage the original plastic surface in anyway."
Good luck!
