There is a novelty to first year of production, Pace car year and the uniqueness of the "one year only" striping. If that matters to you (and it does to me) then a 1996 GTS is your only choice. If it doesn't, then either year is fine. You can find year specific problems with ANY year Viper. For example, 1997's only had bad intake gaskets, 1999's and below GENII's had frame issues that a recall fixed, some 1997's also had porous oil pan problems, all earlier Vipers had side sill corrosion issues, etc. As long as the various TSBs, recalls and any other year specific issues were fixed, you're fine. On Steve's post, as long as you verify the engine VIN, (as you would with any specialty car purchase) review the service history (as you always should)and verify that the engine is dry underneath (as you always should) your set.
