Thread: Engine Start Up
Reply to Thread
Results 1 to 9 of 9
  1. #1
    Join Date
    Jun 2005
    Default Engine Start Up
    I recently purchased an early 93 viper and have been restoring it over the past few weeks. While performing various inspections I had the battery disconnected for several days. After reconnecting the battery, the engine will turn over without a problem it just seems to have a difficult time wanting to fire up.
    I have only given it a few attempts for fear of burning up the starter. I figured I should check with some experts before I did anything I would regret. Any ideas?
  2. #2
    Great Lakes
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    Default Re: Engine Start Up
    You have e-mail.
  3. #3
    Join Date
    Dec 2000
    Orchard Park,NY,USA
    Could be fuel pump related.Turn key to run.build up pressure.then start. GTS Bruce
  4. #4
    Join Date
    Feb 2005
    PA
    I was wondering if she was getting gas as well.
  5. #5
    Join Date
    Sep 2002
    Cuyahoga Falls, OH, USA
    Reset the alarm. The fuel pump may be shut down.
  6. #6
    Has Left the Room!
    Join Date
    Mar 2003
    Phoenix, AZ bye-bye IOWA
    Definitely sounds to me like the alarm needs to be reset. Now if I could just remember how to do it? If you haven't had the opportunity to talk to the Wizard - Chuck Tator - this might be a good chance to introduce yourself to him.
  7. #7
    Join Date
    May 1998
    Definitely the alarm. Take off the drivers side knee bolster, reach up to the alarm module and locate the green wire. From there I do not remember the procedure clearly but I believe you need to press both fob buttons while grounding the wire. Check your manual it should state the process clearly.
  8. #8
    Join Date
    Jun 2005
    I appreciate the advice. I'll give it a try this weekend.
  9. #9
    Join Date
    Jun 2005
    One click of the transmitter and she fired right up.
  1. Start up problems, newly built engine...
    By jp in forum RT/10 and GTS Discussions
    Last Post: 06-18-2003, 01:47 AM
  2. Push Button Engine Start
    By Viper99 in forum RT/10 and GTS Discussions
    Last Post: 06-11-2003, 01:12 PM
  3. Winter Storage: To start or not to start?
    By genXgts in forum RT/10 and GTS Discussions
    Last Post: 01-09-2003, 06:49 AM
  4. engine start up
    By Ron in forum RT/10 and GTS Discussions
    Last Post: 12-13-2001, 01:14 AM
  5. ENGINE START UP&OIL PRESSURE
    By Marv S in forum RT/10 and GTS Discussions
    Last Post: 11-29-2001, 12:29 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
