Thread: Crankcase capacity in an '03?????
Reply to Thread
Results 1 to 8 of 8
  1. #1
    Join Date
    Aug 2001
    Rainbow City, Alabama
    Default Crankcase capacity in an \'03?????
    The manual says 10 quarts, but the technician said the dipstick read "Full" with 8 quarts.
    HELP!!!!
    Don
  2. #2
    Join Date
    May 1998
    Default Re: Crankcase capacity in an \'03?????
    Mine took the amount stated (I think it was 10.5) but now takes over 11 (Paxton). Can't see how it takes only 8. I assume you have the stock oil pan.
  3. #3
    Join Date
    Aug 2001
    Ron,
    This morning, I checked after the car had been sitting for 8-10 hours. The dipstick showed about a quart low, so I added a quart and brought it up to full. Could my dipstick be too long? Ever heard of that??
    Thanks for the info.............
    Don
  4. #4
    Join Date
    May 1998
    Not sure. Note the add oil zone for a Viper is 2 quarts I believe. So if it was at the bottom of the "safe" zone then it is really 2 quarts down.
    1 quart down is not a major thing unless you are going on a track. On track I overfill mine by 1 qt to prevent uncovering the pick-up in left turns. In general over filling is not good (allow crank windage to whip up the oil and can result in highly aerated oil. But in order to prevent starvation it is a good thing.
  5. #5
    Northeast
    SRT10's Avatar
    Join Date
    Apr 2001
    NJ, USA
    With the filter it takes 11 qts!
    Right from the 03 service manual
    Make sure the dirty oil has time to completely drain out.
    I let mine drain overnight and it takes 11 qts everytime!
  6. #6
    Join Date
    Aug 2001
    Well Damn.....................
    In my manual, on page 170, it states that the crankcase (and filter) will hold 10 quarts. Did DC revise the crankcase capacity at some period during 2003?????? Or, do they just want to keep us guessing????
    I think I'm going to stop fretting about it as long as the dipstick shows somewhere in the operational range, i.e., above "add 2 quarts".
    Don
  7. #7
    Northeast
    SRT10's Avatar
    Join Date
    Apr 2001
    NJ, USA
    Don, I believe that you are looking in the "Owners Manual" on page 170. You should pick up the "Service Manual" for the 03 Viper. It's a thick book with all the details and specs for the year Viper. (Some specs change from year to year!) Consider it the bible for your Viper!
    I picked mine up at E-bay and you should have no problem doing the same.
    Good luck.
  8. #8
    Join Date
    Dec 2004
    Guilford, CT-USA
    Age
    64
    SERVICE MANUALS HAVE BEEN KNOWN TO BE WRONG.
    No one on the face of the earth ties up a service bay in their garage to let the oil drain out over night. That said this is what my late production 2003 SRT-10 Viper takes for fluid changes after sitting on the lift draininf for about 15 minutes.
    10 QTS WITH A NEW OIL FILTER.
    3 QTS IN THE TRANSMISSION OR UNTIL OIL RUNS OUT THE FILLER HOLE.
    2 QTS IN THE DIFFERENTIAL OR UNTIL OIL RUNS OUT THE FILLER HOLE.
    THESE ARE REAL WORLD NUMBERS WITH THE CAR SITTING ON MY LEVEL FRONT END ALIGNMENT LIFT. AFTER YOU FINISH DRIVING THE CAR, LET IT SIT FOR A FEW HOURS, AND THEN CHECK THE ENGINE OIL AND TOP UP IF NEEDED.
  1. Crankcase Vacuum Pump, I've got smoke
    By Knight Viper in forum RT/10 and GTS Discussions
    Last Post: 06-05-2007, 10:34 AM
  2. GEN2 Roe Crankcase Breather up for grabs...
    By DAMN YANKEE in forum RT/10 and GTS Discussions
    Last Post: 02-19-2007, 01:14 PM
  3. crankcase ventilation
    By chex in forum RT/10 and GTS Discussions
    Last Post: 11-29-2005, 09:53 PM
  4. Crankcase capacity
    By Don Hiltz in forum RT/10 and GTS Discussions
    Last Post: 09-02-2001, 09:38 AM
  5. Crankcase Breather System
    By in forum New Products and Supplier Specials
    Last Post: 12-31-1969, 07:00 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
