Please Help. Need to find power from ignition and illumination?
Gottaviper
Boston Ma.
My under dash is apart and I am trying to hook up a guage but can not find any wiring diagrams on the site anyone have a pic of a wiring so I don't screw something up. Thanks
SNKEBIT
western wisc.
should be able to find illum. wire from the headlight sw. Tan I think. The keyed power wire is a beehoootch to get at, on top of the column. Light blue I think. Hope this helps. Use a probe tester to be sure you get a"hot with key on" wire. :2tu:
Randy
Earth?
You have always-on power, switched power, and illumination power all at the connector to the sound system head unit (the "radio"), which is where I usually tap low-power-draw items into - such as radar detector, etc. I assume this is a Gen I you are asking about from your signature. If it was a Gen II, you also have a speed sensor wire (for the automatic volume control on the Gen II stock head unit).
Tom R
