Rear window seal project
KWIK96
LA and Oz
Last week I started to hunt around for a new rear window rubber seal for my 2001 RT.
I soon discovered that you cannot get the seal alone, and basically need to buy a whole new window (approx $500)
Well me being half Jewish, half Scottish, and half Irish, I set about trying to find another solution.
After visiting a few trim places and manufacturers I came across a rubber which works pretty well. Installed this morning and pictures are attached. Looks really good and fits well.
For those that are interested;
To remove what is left of the damaged seal I used a Stanley knife. Heat did not seem to help. You just have to cut of the old one and get it cleaned up as best you can. This took me about 1 hour.
I installed the new seal in about 10 minutes using a rubber mallet where needed, mainly on the corners.
Start and finish is top dead centre.
The seal is a tubular bulb design with two lips. I purchased the seal from www.McMaster.com page 3214 #9 (part # 12335 A421) 10ft length.
Total cost was $20.56 delivered to my door.
Will also work for Gen 1 windows
ViperJohn
Maryland
Can you post a picture of the window out of the car?
I would like to see how the corners look.
obaa996
Portland, OR
Awesome info! If anyone else is planning to do this, could one of you please make a tracing/template of the actual glass, so that a new one can be cut?
K
KWIK96
LA and Oz
Here are some more pics. They are a bit hard to see as the rear window is tinted.
The window fits just as good as with the stock seal.
Steam cleaned the car today and it did not leak.
K
KWIK96
LA and Oz
Larry,
I see you are in Real Estate.
Is your sense of humour in Escrow?
SuperSaiks
trying to locate the part on the website can't find it do you have exact link
SuperSaiks
Yo KWIK96
Do you have a exact link to the section on that window seal part, tried to find it can't
ViperJohn
Maryland
Thanks for the extra pics. If it seals as good as it looks, you may have just saved the RT/10 owners a bunch of head ache and money.
The only thing I would try is to put a little heat on the inside corners to get rid of where is sticks out, otherwise it looks terrific.
garolittle
Augusta, GA
Man, this is great. I have been wanting to fix my window for years but thought it would be too much of a pain. Thanks for the tip.
Ag's'95
That looks like a great option, however as an alternative to you guys; I have found a "seal" that is the same "shape" and "dimension" as the one that came from the factory (my car is a 95). The groove that the window sits into is the same depth as the original and the outside part of the seal (the part that touches the car and makes the "seal) is exactly the same. I bought 75 feet of it (smallest amount I could buy) to re-do my window. Like I said just an option if someone wants to go back with something that looks closer to the original. I can send you a pic of the seal itself so you can see the shape if anyone is interested.
garolittle
Augusta, GA
Very cool. Can you post a pic for us? Thanks.
Ag's'95
[/QUOTE]
Ok need some help as I am new at this. Can someone please tell me how to include a pic in my post. I am sorry for my ignorance . . .
slaughterj
Post a pic! So do you have extra? The above solution sounds good, but the seal looks a little "thick" in the sense that it seems to cover more of the window pane...
bth1
New Jersey (Union County)
Ag's'95, where did you order the strip that you used from? Also do you have a part number? Some pics of your completed project would be great. Also, what was the cost?
Thanks.
