I am wondering about the right viscosity and not about the brand !
I have done a couple of research on this matter and my findings are stunning.
In the past I though that running on a thinker oil is better. However it might not be the case ...
Read this regarding viscosity:
(All brands have nearly same viscosity)
10W30
Viscosity at 40C 65
Viscosity at 100C 10
CCS 4000
Flash point 230C
Pour Point -50C
20W50
Viscosity at 40C 155
Viscosity at 100C 18
CCS 5000
Flash point 250C
Pour Point -40C
The 20W50 oil it is obviously two times thicker. Using this motor oil, my engin will generate more friction thus I will loose HP. My engin won't run hotter since the cooling system will compensate. Also my engin will ware quicker.
The only case when this 20W50 oil might be better instead of the 10W30 oil, is when the oil`s temperature goes up to 120C (250F). However above 250F all oil tends ti loose its qualities.
I conclude that the best is to stick to the 10W30.
Am I right ?
10W30
Viscosity at 40C 65
CCS 4000
Flash point 230C
Pour Point -50C
20W50
CCS 5000
Flash point 250C
Pour Point -40C
Am I right ?
