Thread: Fog light lens?
Reply to Thread
Results 1 to 9 of 9
  1. #1
    Join Date
    Mar 2004
    Belvidere, Illinois
    Default Fog light lens?
    Is there any certain way(trick) to install the fog light cover lens? It seems like it would be easy to break off one of the 3 tabs if not very carefull.
  2. #2
    Join Date
    Jul 2004
    Central Illinois
    Default Re: Fog light lens?
    the front fascia is quite flexible. just be careful.
  3. #3
    Join Date
    Sep 2005
    Kelowna B.C., WEStern Canada
    You're right'it is easy to break a tab. Take it slow, make sure the facia is warm (in the sun for a couple hours maybe)it helps when it's most flexable. They are available new, but not cheap, of course.
    I find it easiest to put the top two tabs in and push up to get clearance for the bottom one. Pushing up and in at the same time.
    PS; the service manual is no help on this one, as with most trim related things.
  4. #4
    Join Date
    Mar 2004
    Belvidere, Illinois
    Thanks for the tips! I'm gonna try my luck tomarrow
  5. #5
    Join Date
    Sep 2005
    NY/CT
    Age
    39
    I have a set of Fog light covers in excellent condition if anyone needs them.
  6. #6
    Join Date
    Jul 2004
    Central Illinois
    i do - how much?
  7. #7
    Join Date
    Apr 2005
    Dyess AFB, TX
    Age
    47
    Same here, anyone else have an extra set?
  8. #8
    Join Date
    Nov 2000
    Bloomingdale, IL
    In case anyone is intersted I have 3M headlight and lens cover protectors BRAND NEW for sale. It will fit Gen 1 and 2.
  9. #9
    Join Date
    Mar 2001
    Nashville, TN
    Push the tabs on the inside(the ones that are towards the middle of the fascia) down with one finger. You want your finger to be right on top of the tab. Once it pops out, you can then easily remove the lens. Reverse the procedure to put them back on. I just pulled mine off today to clean them, so it's still fresh in my mind.
  1. Fog light lens removal
    By mad0953 in forum RT/10 and GTS Discussions
    Last Post: 10-14-2006, 09:38 AM
  2. Fog Light Lens???
    By troyrt10 in forum RT/10 and GTS Discussions
    Last Post: 05-24-2005, 09:50 AM
  3. Fog light lens question
    By NY VIPER in forum RT/10 and GTS Discussions
    Last Post: 06-11-2004, 04:20 PM
  4. Fog light lens cover - need one!
    By slaughterj in forum RT/10 and GTS Discussions
    Last Post: 02-10-2003, 11:22 AM
  5. Light lens covers
    By Vip-RT10 in forum Archive Management
    Last Post: 03-14-2001, 12:14 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
