Keep im mind a new PCM will start with zero.
Matter of fact, I used to run 2 different pcms, for a weekend of racing, or drag strip, I would run mopar, for street I would use my oem one. Each one only takes the miles they record, so for a 100 miles i could split them on 2 pcms, and so if you use that as a determinant, its going to be scewed also.
Do a car fax, and if it had to get serviced at dodge, or dmv emissions, its got records, those would be a good indicator if an tampering has occured.
Jon
PS. And with and DEalership ODBII/III device, its easy to reset that counter to zero, or ANY other number to match your current odometer.
