Thread: Tire repair or not to, or just buy a new one??
Reply to Thread
Results 1 to 10 of 10
  1. #1
    Join Date
    Oct 2006
    Pensacola, FL
    Age
    53
    Default Tire repair or not to, or just buy a new one??
    Just got a flat. I have the max care and tire and wheel coverage.
    Is it safe to repair? i.e. @ 185MPH
    Will the dealer insist on a repair or is a Z rated tire not recommeded for repair?
    Has a nail about three inches from the outside edge.
    Anybody know.
    Scott
  2. #2
    Join Date
    Sep 2005
    Columbus, Ohio
    Default Re: Tire repair or not to, or just buy a new one??
    They will tell you they can repair it, if it isn't too close to the edge...the problem is that will lower your "z" rating to a "r" rating and won't except as high of speed...so if you can talk them into switching the tire, i would do that.
  3. #3
    Great Lakes
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    I PERSONALLY do not keep a repaired tire on a high performance car.
    That said, I believe that Michelin notes that there is an acceptable way to perform some repairs(locaton and size matter) without negating the speed rating by using an internal patch with an integrated plug...assumimg also that the tire's date code is less than 6 years.
  4. #4
    Great Lakes
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    An old thread:
    http://www4.forum.viperclub.org/showflat...true#Post534541
    Ryan's point may be right on the money.
    I am NOT sure just what speed rating that you end up with even using a "proper" plug/patch repair. This can become especially important in a Viper since "impulse" can occasionally over-ride the memory of past repairs during "spirited driving" situations.
  5. #5
    Join Date
    Feb 2005
    PA
    Here's an idea I had but never used. When they do plug your tire, take it back like 2 or 3 days later and make it a few pounds low right before you get there, and do this as many times as you need to until they give you a new tire. Tell them they never fixed the problem. Haha. It's worth a try at least! You gotta get angry with them too.
  6. #6
    Join Date
    Apr 2005
    Age
    35
    Buy a new tire, i wouldn't trust some crappy plug at 185 mph much less over 100 mph. If you can afford to own a viper, then you can afford to buy a tire. Thats what i would do, why take the chance ya know?
  7. #7
    Join Date
    Mar 2003
    UK
    Would it be better to have a repaired tyre of similar age and wear Patten to the other and which is never driven over 90mph (110 max) or have nice shiny new sticky rubber with double the tread depth on one side and old part worn on the other.
    I'd have thought the single new tyre would be more likely to cause upset to handling at normal highway speed than a repair. On the other hand if you are driving hard/tracking then you can afford to buy two.
  8. #8
    Join Date
    Jun 2005
    Indiana
    Age
    57
    repair the old one, keep it as a spare in the garage and go get a new one
  9. #9
    Northeast
    Bonkers's Avatar
    Join Date
    Feb 2002
    DelaWhere? USA
    go get a new one
    Ditto. If you weren't planning any major speed runs a plug/patch
    would be fine, but if you're looking at attempting 185mph you need
    tires at 110% (not including balancing.) Blowing a plug at that
    speed would be.... well lets just say it'd be the last thing you'd
    ever regret going cheap on...
  10. #10
    Join Date
    Apr 2005
    Age
    35
    Great idea!
  1. Viper Tire Repair in North/Central FL?
    By viperbob in forum General Viper Discussion
    Last Post: 04-13-2007, 02:02 PM
  2. Tire repair in N. Tampa, FL area
    By viperdude118 in forum RT/10 and GTS Discussions
    Last Post: 08-29-2006, 09:15 PM
  3. Welcome to the Tire Rack sponsored Wheel, Tire, Brake and Suspension Forum
    By Jay Herbert in forum Tire , Wheel, Brake and Suspension
    Last Post: 01-21-2006, 12:05 AM
  4. Tire repair
    By Bad Asp in forum General Viper Discussion
    Last Post: 08-04-2003, 07:23 PM
  5. Has anyone here had to repair a rear tire (nail hole etc..) ?
    By TAPROOT in forum RT/10 and GTS Discussions
    Last Post: 05-08-2002, 09:41 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
