Thread: Tire sensor monitor repair
Reply to Thread
Results 1 to 6 of 6
  1. #1
    Join Date
    Jun 2007
    South CT
    Age
    34
    Default Tire sensor monitor repair
    Anyone know how much of a pain/cost this is to repair?
    Im looking at an 04 and the tire sensor light it on, but the air is fine in all 4. The guy selling it says its a faulty monitor and the warning goes off after a few minutes of driving. Granted, not a big deal, but I think it would kind of annoy me. The car has aftermarket wheels and I suspect when they were mounting the tires they damaged it. My buddy has an 07 vette and needed the tire replaced and they broke the sensor and he had to shell out a couple hundred to have it repaired.
    Any thoughts?
    Mark
  2. #2
    Join Date
    Jul 2006
    Default Re: Tire sensor monitor repair
    Can you see the sensors to know for sure that they actually have them in? I have sensors in my wheels, but there mounted inside, so you dont actually see them. And the tire chime is annoying, I drove for 2 days with my stcok wheels without the sensors in. It bugged me, it would chime for about 5 minutes, then sometimes go off and come back on a few minutes later. Even the radio wasnt enough to supress it.
    Also, I dont know how hard it is to determine what sensor is bad, but first you have to figure that out then get it replaced and I believe only the dealer can reprogram the new sensor.
  3. #3
    Join Date
    Feb 2002
    Buffalo NY, USA
    Likely has a dead wheel sensor battery or bad sensor somewhere. They are about 50-60 bucks per sensor last I checked, plus the mount/dismount fees. Replace in sets of 4.
  4. #4
    Join Date
    Oct 2000
    tampa, fl USA
    Proven trouble-free tech. Somebody tell Congress.
  5. #5
    Join Date
    Jun 2007
    Boise, Idaho
    Discount Tire rebuilds them for $9.95 each. I was in getting new tires and got the sales pitch that this needs to be done every time new tires are installed
    ________________
    08 Viper coupe
    05 SRT-10 RC Ram
    07 Z06
    07 Tahoe 4x4
    03 Ram QC Hemi
  6. #6
    Join Date
    Nov 2000
    UK
    Age
    64
    Had the same problem on my 04 and it was a duff sensor, you can tell if they have low pressure senders as the tire valve will have a nut that looks aluminium as will the stem.
    Even if you change the sensor you appear to still require a Dealer or a DRB as each wheel sensor is on a different numbering system and the ECU needs to be told which sensor relates to which tire.
    In my case I had changed the sensor but the ECU needed telling to look out for the new valve unit.
    BTW it also takes several miles or minutes for the system to detect a re-educated valve so the light will still not go out instantly even with the DRB as the wheel needs to rotate at over 30mph before the tire is recognised as good.
    Mine was a PITA and it took me a long time to understand the system.
  1. Is there a tire pressure sensor in the rim?
    By Jsparks in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 12-18-2007, 08:28 PM
  2. Low Tire Sensor
    By Shandon in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 02-10-2007, 04:30 PM
  3. Tire repair or not to, or just buy a new one??
    By Scott5ppg in forum RT/10 and GTS Discussions
    Last Post: 01-27-2007, 07:43 PM
  4. Tire sensor ??
    By prevnine11ownr in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 03-08-2005, 10:22 PM
  5. Tire repair
    By Bad Asp in forum General Viper Discussion
    Last Post: 08-04-2003, 08:23 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
