Thread: Mopar oil filter vs. Mobil 1 filter?
Reply to Thread
Results 1 to 12 of 12
  1. #1
    Join Date
    Apr 2003
    Spring, Texas
    Default Mopar oil filter vs. Mobil 1 filter?
    May have already been addressed, but is the Mopar factory oil filter as good as the Mobil 1 filter for Gen 2? Thanks in advance.
  2. #2
    Join Date
    Jul 2007
    Default Re: Mopar oil filter vs. Mobil 1 filter?
    Depends on what parts counter you are at.
    Auto Zone, or Dodge.
  3. #3
    Join Date
    Apr 2003
    Spring, Texas
    Quote Originally Posted by dave6666 View Post
    Thats the kind of reply Jon B. and myself like. OK, Tom, the oil and lube pro, I took your honest and very educated advice on the oil weight, now how about this one? Thanks Tom.
  4. #4
    Join Date
    Apr 2006
  5. #5
    Midwest
    mjorgensen Woodhouse's Avatar
    Join Date
    Jun 2005
    Omaha NE.
    I'm not Tom but I would NEVER use a Mobil1 after cutting one open and seeing how much oil it can bypass at cold start and when the ultra low filtering system plugs off. The Wix/Mopar is really the only choice IMVHO.
    Mark Jorgensen, Manager
    woodhousemotorsports.com 402-677-2935 Cell
  6. #6
    Gateway
    Ron's Avatar
    Join Date
    Oct 2000
    Indianapolis
    According to some knowledgable people (not me) unlike their air filters, K&N oil filters seem to have the right compromise between flow and filtering.
    Ron - '96 GTS
  7. #7
    Join Date
    Apr 2003
    Spring, Texas
    Quote Originally Posted by mjorgensen View Post
    Interesting info and thanks. Can you answer this? I have a new Mopar/Viper filter part no. 05037836 from VOI 9. Will this fit the Gen 2 motor?
  8. #8
    Midwest
    Join Date
    Jun 2005
    Omaha NE.
    Quote Originally Posted by VIPER GTSR 91 View Post
    Yes it will these filters will fit "all" the Vipers except the 08' cars that have a new filter and the size of the threads are bigger to distinguish it.
  9. #9
    Join Date
    Jul 2007
    Assuming there needs to be a balance between excess bypass during cold start and oil starvation during cold start, you are leaning toward the Mobil 1 is too much flow when cold? In other words, too much bypass? I mean, you said how much oil it can bypass. Does that mean it is? Has anyone ever studied these things in real life, short of the workbench top dissection?
  10. #10
    Midwest
    Join Date
    Jun 2005
    Omaha NE.
    Yes it can bypass when cols or when it plugs off as any filter can. The really small micron filtering ones though will generally get to the bypass mode sooner than conventional filtering media. The Wix/Mopar has good surface area and the stout spring rather than the heat affected leaf spring type of bypass spring that may even fail as some test have shown.
    I'm just saying that the design to me is a better one than advertising the smallest micron filter. and potentially bypassing excess oil during start up pressure spikes when the engine needs clean oil more.
  11. #11
    Join Date
    Jul 2007
    Got it. Now what is the reason for engines really needing clean oil at startup? I would think if it's related to clearances and particle size, that while the engine is cold clearances are greater, allowing greater particle size to pass without damage to bearings and journals.
  12. #12
    Midwest
    Join Date
    Jun 2005
    Omaha NE.
    Dirty oil with particles flowing into an un oiled space do not have them in "suspension" and they can be the primary surface contact until the bearing is flowing with oil. I see this as potential wear on the bearing surface.
  1. Quick consensus - Mobil 1 filter or Mopar?
    By AG98RT10 in forum RT/10 and GTS Discussions
    Last Post: 03-31-2004, 09:08 PM
  2. What type of Mobil 1 and filter recommendations:
    By georgekessel in forum RT/10 and GTS Discussions
    Last Post: 03-28-2002, 08:30 PM
  3. Mobil 1 Oil Filter Failure...... (Long)
    By Janni in forum RT/10 and GTS Discussions
    Last Post: 09-27-2001, 06:55 PM
  4. Mobil 1 Oil Filter Failure...... Analysis
    By slaughterj in forum Archive Management
    Last Post: 06-26-2001, 12:40 AM
  5. Mobil 1 oil filter... Who carries them?
    By SNK BIT in WA in forum Archive Management
    Last Post: 03-20-2001, 09:06 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
