Thread: Windshield wipers not in sync
Reply to Thread
Results 1 to 13 of 13
  1. #1
    Join Date
    Oct 2000
    Ocala, FL USA
    Default Windshield wipers not in sync
    Yesterday, we took the Viper out for a short trip to a nice out of the way restaurant in the Crystal River area of Florida (Peck's Old Port Cove Restaurant on Ozello Trail in Crystal River FL), and on the way, it drizzled a bit. We even had the top down during the light rain, and I turned the wipers on just to clear the drops off the windshield. Well, the driver's side wiper started up ok, but the passenger side wiper was not in sync with it, and they jammed together, locked up and bent the blade on the passenger side. I had to get out of the car and unjam them manually, or they would have stayed locked up together right in the middle of the windshield. Has anyone else had this happen, and how is it fixed? Not that I drive the car in the rain, because I don't, (this is only the second or third time in its soon to be 10 year life with us that the wipers have been on to clear off the windshield), but I would like to know what happened and how or if I can fix it just in case I need them at some future date.
    Any replies would be greatly appreciated!
    Thanks!
    Roland L Ocala, FL
  2. #2
    Join Date
    Oct 2000
    Wappingers Falls
    Default Re: Windshield wipers not in sync
    The wiper motors have position sensors that tell a black box where each blade is. A typical failure is as you describe - but it is the motor that behaves correctly that is usually the problem. It doesn't care where the other arm is, while the good motor acts erratically trying to dodge the bad one.
    To start, replace the passenger motor. Hopefully you have a Viper neighbor that might even swap their good one to make sure that is the issue. If still not good, by then you might have an idea whether to replace the passenger motor and/or the black box (which is located under a false floor in the passenger foot well.
    Until then, maybe take the passenger arm off so you can travel in the wet.
    My story...
    http://forums.viperclub.org/rt-10-gt...nt-wipers.html
    http://forums.viperclub.org/rt-10-gt...ld-wipers.html
  3. #3
    Join Date
    Oct 2000
    Ocala, FL USA
    Thanks Tom. From what you said, I think it is the passenger wiper motor. However, I will just take off the passenger side wiper for now, as the car just does not go out in the rain.
    Roland L - Ocala
  4. #4
    Join Date
    Oct 2000
    Wappingers Falls
    You might have to have them both working to pass your state inspection.
  5. #5
    Join Date
    Jan 2003
    Mi, USA
    This happened on my 96. The dealer replace both motors.
  6. #6
    Join Date
    Apr 2006
    Birmingham, AL
    This also happened to my 96 GTS recently. Are you saying it's possible that the dealer will replace them for free? I heard the motors are INCREDIBLY expensive and I have to pass my local inspection to get my car tagged again.
  7. #7
    Join Date
    Mar 2001
    Nashville, TN
    Quote Originally Posted by androbud View Post
    My guess is they will replace them only if the car is under warranty, otherwise they will replace them and give you a nice bill.
    I didn't realize the Viper had a high tech windshield wiper system.
    I had a similar problem occur on my '01 Avalon. Turns out the nut holding down the driver's side wiper arm had become slightly loose allowing the wiper to be out of sync. The result was stuck wipers in the middle of my windshield. With the wipers in the off position, I loosened the nut, pushed the driver's side wiper arm down to where it should be, and then tightened the nut. Problem fixed.
  8. #8
    Midsouth
    Chuck 98 RT/10's Avatar
    Join Date
    Oct 2000
    tampa, fl USA
    Quote Originally Posted by Tom, F&L GoR View Post
    No state inspection in Florida
    Chuck 98 RT/10
    BabelMotorsports.net
    SAFEMotorsports.com
  9. #9
    Join Date
    Dec 1997
    Quote Originally Posted by snakebitdave View Post
    That's becasue your dealer did not have the benefit of Tom's sage advice.
    Your dealer took the un-informed SHOTGUN approach!
    On Gen 1-2, the wiper that is "ACTING STUPID" is 95% likley to be the GOOD MOTOR.
    The motor that STAYS NORMAL is 95% likley to be the BAD MOTOR, somply being 'corrected' by the under-Rt-foot controller (which almost NEVER goes bad)
    PS. PartsRack has wiper motors from organ donors....your replacement need not be expensive.
    JonB~ Int'l Viper Registry NW Region Charter Pres 93-95;VCA "Founding Fourteen" 1995;VCA Nat'l Secty-Treasurer 95-97;VCA Nat'l Secretary 98-99;VCA NW President 95-02;VCA National / Regional Sponsor 96-13;SRT Viper Cup Sponsor, 2010-13
  10. #10
    Join Date
    Oct 2000
    Wappingers Falls
    I think I learned this from a Wiser Sage named JonB.
  11. #11
    Join Date
    Nov 2004
    UK
    I 've got a simpler problem (i hope...!): is there a knack to getting the wipers detached from the projecting threads?!! Manual says rocking motion should do it, but it seems as if both mine are locked onto the threads! Have tried all the different rocking motions 3 dimensions will allow but no budge as yet. Don't want to go mad and wreck/ dismount the motors...! Any thoughts please?
  12. #12
    Join Date
    Oct 2000
    Wappingers Falls
    No trick. The arms are on tapered splined shafts, so a straight pull upward "should" remove them. Perhaps some anti-rust lubricant or WD-40 and wait a day.
  13. #13
    Join Date
    Apr 2004
    Cedar Park
    wow...good thread!
  1. Important Advice for failed windshield wipers
    By Tom, F&L GoR in forum RT/10 and GTS Discussions
    Last Post: 07-10-2008, 02:54 PM
  2. Wipers? Vipers don't need Wipers!
    By Ratical2 in forum General Viper Discussion
    Last Post: 10-24-2007, 10:29 AM
  3. Gen 2 Throttle Body Sync
    By ViperBing in forum RT/10 and GTS Discussions
    Last Post: 06-06-2007, 09:41 PM
  4. windshield wipers
    By knuk in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 03-26-2003, 08:07 PM
  5. Wipers out of Sync
    By Greg 99ACR Red and Silver in forum RT/10 and GTS Discussions
    Last Post: 10-18-2001, 12:30 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
