98 Viper GTS Battery Location
racnfevr
California, MD
Where is the battery located and how do i accesss it? I think I have to remove the driver side rear tire but not real sure.
Viper Newbie
Vreracing
Amarillo,Texas,USA
I removed the drivers side wheel and here it is.
I don't remember there being anything remarkable about changing it.
I have a 98 GTS. This picture is six years old.
He meant to say " remove the LEFT rear wheel" and splash guards.
There is an excellent description of this in the illustrated guide section (complete with photos and tips) that was posted by ViperTony ...also, I posted a list of necessary tools in another thread...see below
"Be Prepared...and it WILL go well. Here's an old post of mine that may help:
It's not a bad job...goes well if you plan ahead and have tools ready.
Use a 3/4" (or 19mm) socket to remove left rear wheel. Then use 8mm, 11mm, and 10mm sockets to remove fasteners on splash shield in rear of fender well, and a pair of needle nose pliers to pull the plastic push pin that holds the battery cover to the splash guard...now disconnect the battery using 5/16" socket, and use a 1/2" socket to remove battery clamp.
Inspect the tray carefully...you will likely see corrosion...if so, neutralize it CAREFULLY by scrubbing with water and baking soda. DO NOT USE COMPRESSED AIR to clean this out !!!
After the area dries, I usually use a wire brush on an electric drill (wearing goggles and a respirator/face mask) to remove all remaining oxidation caused by the acid and/or rust. I wipe the tray WELL with rags, then allow it to dry. Then, after a couple more wipe-downs with ethyl alcohol to remore moisture, debris, and oils... I coat the tray bottom and sides with Rustoleum primer 2-3 times...and when dry, hit it with a couple of coats of Rustoleum black "engine gloss" even a semi-gloss. I have found that a used pizza box slid right under the battery tray makes a great "paint booth". After this is completely dry, install new battery (I PREFER a 75 series as they ALWAYS fit our various Vipers...and I always use a Sears Die-Hard Gold...noting that the LEAST amout of usage that these batteries have given me is 6.75 years). Then put it back together.
Note: SOME 94's will not start after battery disconnect...so you might wish to try it before installing the covers. If you have trouble...call me...or do a "search".
I do use a 9 volt battery plugged into the cigarette lighter...which maintains the clock and radio settings for a reasonable time.
HAVE FUN...and don't drop your Viper on yourself !!!"
Vreracing
Amarillo,Texas,USA
I was hoping someone would jump in. I hate to see an orphan post sit there too long.
Basically, if I can do it, anyone should be able to.
It's remarkable that the battery is still working after 6 years.
Here's what it looked like after the battery was removed.
Dugger
