Thread: 2001 GTS left rear tail light lens replacement
Reply to Thread
Results 1 to 6 of 6
  1. #1
    Default 2001 GTS left rear tail light lens replacement
    Does anyone know how to replace the left rear tail light lens on a 2001 GTS, and where to get one.
    VENEMOS
    [email protected]
  2. #2
    Join Date
    Jan 2006
    Default Re: 2001 GTS left rear tail light lens replacement
    Quote Originally Posted by asomerset View Post
    VENEMOS
    [email protected]
    The tail light lens is the same for all year GTSs'. It is also the same tailight as the 06,08 coupe. They are all the same. You can get a new or used one from Mike at XVIPERS INC
  3. #3
    Can I just change the lens, or do I have to replace the whole assembly.
  4. #4
    Join Date
    Oct 2008
    Tacoma, WA
    Age
    35
    Replacing the bulbs or entire unit is straightforward:
    1. Pull back the carpet. Pull out the rubber grommets (top three give access to the brakelight nuts, bottom two to the turn signal/back up light).
    2. You'll need a socket extension to get in there and twist off the plastic nuts--I think it's an 11mm or equivalent English (can't remember which). Be careful with them, as they round off easily.
    3. Once the nuts are off, you'll be able to pop the whole lens assembly out the back and replace bulbs as necessary or the whole thing. The bulbs simply twist off and pull out of their sockets.
    4. Reverse to install.
    The lens and plastic back are one unit, with three holes for the bulbs.
  5. #5
    Join Date
    Sep 2004
    Eagle River, WI
    I have a used tail lamp if you want to go that route, I assume you need the red "upper" portion of the lamp, as the turn signal/back up lamp are a separate part. New list is $ 280, I will sell a used one for $175 plus shipping. Contact me if interested, Paul Scharf 800 338 4002
  6. #6
    Quote Originally Posted by treesnake View Post
    Sorry for the insane thread necro, buuuuuut, is this the case for the lower clear portion as well?
  1. Fog light lens?
    By SNAKE BITE in forum RT/10 and GTS Discussions
    Last Post: 06-11-2006, 12:16 AM
  2. RED/WHITE REAR Blinker light replacement
    By ViperJames in forum RT/10 and GTS Discussions
    Last Post: 03-05-2006, 01:38 PM
  3. Fog Light Lens???
    By troyrt10 in forum RT/10 and GTS Discussions
    Last Post: 05-24-2005, 09:50 AM
  4. 2001 Rear Brake Pad Replacement
    By Rich01RT10 in forum RT/10 and GTS Discussions
    Last Post: 10-26-2002, 10:36 AM
  5. Light lens covers
    By Vip-RT10 in forum Archive Management
    Last Post: 03-14-2001, 11:14 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
