Thread: What happens if I mix up spark plug wires?
Reply to Thread
Results 1 to 16 of 16
  1. #1
    Join Date
    Feb 2009
    Default What happens if I mix up spark plug wires?
    Lets say I mixed up and crossed over two spark plug wires. What is the worst that could happen and how the car will behave to show me that I missconnected wires to the wrong cylinders?
  2. #2
    Join Date
    Nov 2008
    Default Re: What happens if I mix up spark plug wires?
    are you high or serious?
  3. #3
    Join Date
    Jan 2008
    Surrey, United Kingdom
    It will not run right! The car will be misfiring, the valves / pistons will not be in the correct position for the spark detination
  4. #4
    Join Date
    Nov 2008
    hey-lets say i weld some wings on my car-will it fly?
  5. #5
    Join Date
    Feb 2009
    Quote Originally Posted by bluesrt View Post
    Yes, yes, I know stupid question, I don't think I ever had the issue of crossing wires, so I don't know how the car should behave in case I did.
  6. #6
    Join Date
    Aug 2009
    NW Jersey
    You could potentially destroy the intake and/or blow the gaskets or worse especially if you ignite the intake stroke...
  7. #7
    Join Date
    Jun 2003
    ALL OVER
    Age
    49
    What makes you think you have a wire installed wrong ?
  8. #8
    Join Date
    Mar 2002
    Houston, Texas, USA
    As others have mentioned, the car will run like crap (rough idle and misfire). And if you don't know what 'runs like crap' means, you'll know that it now doesn't sound or feel (shakes more) the same as it did before. Rule of thumb when changing wires: Change them one at a time!
  9. #9
    Join Date
    Feb 2009
    Quote Originally Posted by Flexx91 View Post
    Ok, thank you guys. I am safe for now .
  10. #10
    Join Date
    Jun 2007
    The Woodlands, Texas
    "Whatever you do, don't cross the streams!"
  11. #11
    Join Date
    Oct 2008
    it will run like a corvette
  12. #12
    Join Date
    Jul 2009
    Poconos Pennsylvania
    Age
    31
    Quote Originally Posted by Chelseasnake View Post
    Ive got to tell the corvette owners in my family that one.
  13. #13
    Join Date
    Jun 2005
    Rochester, NY
    LMAO That was the best laugh I had this week. Like the above poster said, change one at a time. I have in my youth crossed wires on my old DD and the results weren't catastrophic because I turned it right off rught away but lets just say it didn't sound good.
  14. #14
    Join Date
    Dec 2006
    Colorado
    If you have to ask this very question, I would say maybe someone else should fix your wires for you. The answer is simple, pull them all off and install them one at a time according to the firing order. They are geneally length specific to the cylinders.
    If you get them wrong, the car will A.) not start at all or B.) Run like crap. If B.) then shut car off immediately and figure out where you went wrong. That very brief few seconds runtime on improperly wired coils will not hurt it, just don't let it run forever and start reving it up. You should know within 1/2 a second if it is wired wrong. If you can't figure it out, again maybe you should not be working on that part and get someoe else to do it for you.
  15. #15
    Venomiss
    Guest
    Get a picture of your engine before starting to change them out so you have a reference for yourself.
    Don't cross the streams-too funny. Is he the keymaster or the gatekeeper?
  16. #16
    Join Date
    Jul 2009
    Calgary, Alberta
    Hmmm I thought it would just sound like it had a large cam in it??
    Tony2
  1. Spark Plug Wires
    By 2snakes4us in forum RT/10 and GTS Discussions
    Last Post: 06-19-2007, 11:55 AM
  2. Does anyone have a set of used spark plug wires set that are OEM?
    By Qualitywires.com in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 08-11-2006, 06:19 PM
  3. Spark Plug Wires
    By 98viperGTS in forum RT/10 and GTS Discussions
    Last Post: 05-17-2006, 07:49 AM
  4. Spark Plug Wires-8.0 or 8.5 ?
    By jimandela in forum RT/10 and GTS Discussions
    Last Post: 06-04-2002, 07:51 PM
  5. Spark Plug Wires
    By Fred(DrivingSchool)Kinder in forum Archive Management
    Last Post: 01-21-2001, 02:41 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
