Need pictures
InjectTheVenom
I need pictures of this particular corner in between the seat and door facing outward looking directly at the sportsbar/quarter panel/rear section transition.
I
InjectTheVenom
Thanks Chuck that already provides some help, however I was looking for the bulkhead area behind the seat where it meets up with the rear clamshell. Hope you had a good time at Sebring :2tu:
I
InjectTheVenom
Yes. Seat out of the way, facing the bulkhead towards the sportsbar/door area just like in the second picture with red outlines.
Crompton
Alberta Canada
i will check and see what i have.Just did the yearly seat removal cleanning and may have taken a few that could help out.
Crompton
Alberta Canada
will these help?
I
InjectTheVenom
That's perfect guys, thank you both very much :2tu:! Now I know how to continue with my scale model project :)
I
InjectTheVenom
Will do but that finished product still has a loooooooong way to go!
I should probably change the title of this topic because now I need CAD files for the complete dashboard (including vents, gauges.. the works) and the wheels.
Sizes of the wheels that come with the Revell kit (I want to be able to keep the tires):
Width of a front wheel is 11,10mm or 0.437 inch, diameter 19,20mm or 0.756 inch.
Width of a rear wheel is 13,80mm or 0.543 inch, diameter 19,20mm or 0.756 inch.
Kevsmu4
