Thread: HELP: Part number of temperature sensor
Reply to Thread
Results 1 to 8 of 8
  1. #1
    Join Date
    Apr 2007
    Austria / Europe
    Default HELP: Part number of temperature sensor
    My radiator sometimes wont work.
    As i allready changed both relais which switch the radiator (on/off and also low/high) next step is to change the "Engine Coolant Temperatur Sensor".
    It is the one which is in the front of driver side cylinder head and gives the signal to the temperature gauge.
    My local Chrysler dealer in switzerland doesnt find the part number.
    Can anybody help please?
    Thanks and greetings from good old Europe
    Rainer
  2. #2
    Join Date
    Jul 2007
    Default Re: HELP: Part number of temperature sensor
    4848110
    Please send both chilled ales and some of them hotties I always see on postcards and we'll be even old chap.
    Also pull your relays back out and check to make sure there is no burning in the relay socket area. Short out (jumper) if you can the relay contacts and check for 12 volts at the fan wire plug. Also inspect it for proper connection.
  3. #3
    Join Date
    Apr 2007
    Austria / Europe
    [quote=dave6666;2855474]4848110
    Hi Dave
    Thanks for your fast help !!
    I will go overseas in Oktober - spending a week in LasVegas.
    If you will be there also i can spend you some ales and maybe some hotties in a table....bar, but i think Texas is a little bit far away....
    Greetings from Austria
    Rainer
  4. #4
    Join Date
    Jul 2001
    Talking Re: HELP: Part number of temperature sensor
    IF Dave is in SLC for VOI-11 (why not you, Rainer?) I will have a beer or two ... with him toasting to the fine ALPINE women ...
  5. #5
    Join Date
    Apr 2007
    Austria / Europe
    Quote Originally Posted by ViperGTS View Post
    Hi Markus
    Looks like "Oktoberfest" in Munich
    I am in Las Vegas at the end of Oktober with 5 friends from our "Poker-Club"
    Wrong time - wrong place....
  6. #6
    Join Date
    Dec 1997
    I can clearly see FIVE ALPINE PEAKS in that photo......
  7. #7
    Join Date
    Jul 2007
    I like women that kiss each other while their eyes undress you.
  8. #8
    Join Date
    Sep 2005
    Kelowna B.C., WEStern Canada
    Quote Originally Posted by dave6666 View Post
    I prefer it when they undress each other and kiss you with thier eyes.
  1. Battery Temperature Sensor and Optima Battery
    By VNMOUS in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 08-23-2006, 12:06 PM
  2. Need Help with Part Number
    By SHEVIPER in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 08-05-2006, 07:31 PM
  3. Installing oil temperature sensor
    By Schulmann in forum Performance Modifications
    Last Post: 12-14-2004, 04:37 PM
  4. Installing oil temperature sensor
    By Schulmann in forum RT/10 and GTS Discussions
    Last Post: 12-13-2004, 08:51 PM
  5. O2 Sensor Part Number
    By HOdbleFman in forum RT/10 and GTS Discussions
    Last Post: 09-18-2004, 11:21 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
