Thread: Bad Smell Coming from Air Conditioning / Vents
Reply to Thread
Results 1 to 12 of 12
  1. #1
    Join Date
    May 2010
    Calgary Alberta, Canada
    Default Bad Smell Coming from Air Conditioning / Vents
    Hi.
    I bought my Viper at the end of April, and noticed a very musty, urine-like (I know, yuck!) smell coming from the vents every time I get in the car.
    Is there some kind of air exchange / air filter that needs to be changed?
    Any ideas where this smell could be coming from?
    Please help. Driving the car is becomming unpleasant.
  2. #2
    Join Date
    Nov 2008
    Default Re: Bad Smell Coming from Air Conditioning / Vents
    a normal mold in your heater/ac box---they make a solition to spray in your fresh air intake to kill it-- i like the smell of it and people think im nuts lol
  3. #3
    Gateway
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    What he said...but, in my experience, occasionally a small leak of R-134a has a moldly smell as well. Try the spray...but if along the way your A/C blows warm and frequently cycles on-off-on-etc., check your system for pressure readings and for a leak using the R-134a refills with dye, UV light/goggles, and a "sniffer".
  4. #4
    Join Date
    Apr 2008
    "OIHO"
    Not to scare you but check for pests as well. The "urine like" smell could in fact be just that.
  5. #5
    South
    gb66gth's Avatar
    Join Date
    Dec 2007
    Big-D
    Mold. Most of them have that same smell.
    I've even heard of spraying Lysol in there, to kill the mold
    '05 Black SRT10 vert.
    '08 Black SRT10 vert.
    '66 Shelby GT350H "Rent-A-Racer"
  6. #6
    Join Date
    Dec 1997
    Quote Originally Posted by ChoklatMan View Post
    Hi.
    Mice. Yup. Could well be a nest in the A.C intake plenum, esp on cars that are winter-stored. You should put some "Dryer Sheets" in every nook and cranny you can when stored...
    JonB~ Int'l Viper Registry NW Region Charter Pres 93-95;VCA "Founding Fourteen" 1995;VCA Nat'l Secty-Treasurer 95-97;VCA Nat'l Secretary 98-99;VCA NW President 95-02;VCA National / Regional Sponsor 96-13;SRT Viper Cup Sponsor, 2010-13
  7. #7
    Join Date
    Oct 2006
    Fremont,MI
    Also check the A/C drain, could be plugged. Try spraying some 'ozium' air sanitizer in the A/C air intake while the A/C is on.
  8. #8
    Join Date
    Dec 2006
    Colorado
    More than likely just mold on the coils. Use the right spray into the intake part with the fan running and then into your vents on the interior with the fan motor not running. It will go away after applying it a few times. In climates like Alberta where it can be a little humid at times followed by dry spells, it is the perfect condition for that to happen. It happens here in Colorado at times too. Not in my Viper but in my Porsche. I take it, it is worse, AFTER a recent rain followed by heat?
    If you see little droppings in the carpet or trunk or in the engine bay nooks and crannies, then you know you have a real rodent problem.
  9. #9
    Join Date
    Dec 2000
    Orchard Park,NY,USA
    Lysol spray while cycling all the vents,ac ,heat etc. GTS Bruce
  10. #10
    Join Date
    May 2010
    Thanks everyone!
    I've got the car booked into a local dealership first thing Monday morning. They're going to fog it and get rid of the mold. When I took it in, they said it was a common problem - especially with vipers because they run so hot and the air conditioning is used more than most cars.
    Looking forward to driving the car in the mountains and smelling MOUNTAIN air!!!
    I'm glad it's just mold. I've had a few guys tell me of instances where people have actually urinated in their cars when parked with the tops down. Unbelievable....
    Cheers!
    Brad
  11. #11
    Join Date
    Dec 2006
    Colorado
    That is only those drunk rednecks in Fort Mac Brad. Ha! Ha!
  12. #12
    Venomiss
    Guest
    Good luck with it and hope they can fix it for you.
    The thought of that is just EWWWWWW.
  1. Steam coming out of vents. Heater issue?
    By TorQ Junkie in forum RT/10 and GTS Discussions
    Last Post: 11-29-2008, 10:46 AM
  2. Antifreeze smell...Where is it coming from?
    By RTED in forum RT/10 and GTS Discussions
    Last Post: 11-13-2005, 06:00 PM
  3. When i come to a quick stop, a stink smell enters in the AC vents
    By vegasviper in forum RT/10 and GTS Discussions
    Last Post: 08-15-2005, 10:40 PM
  4. Repost: Anyone making vents to use fog holes as brake vents.
    By PhoenixGTS in forum RT/10 and GTS Discussions
    Last Post: 06-30-2005, 06:44 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
