Temperature Control/Selector Knob Broke
sgreiner1011
Webster, MA
Hi All, My temp control knob on the dash broke on my 94 RT10. It cracked inside. So now it will just keep turning and turning. Does anybody know if any other car uses the same knobs? I know the vipers used some of the same parts as other dodge vehicles. I can't find anything online for a Viper so I was thinking about looking into other modelss to find one. Does anybody know? Thanks!
NI-KA
Canton, Ohio
If you order the controller from Dodge/Chrysler I had alot of problems with bad stock this summer. The stock had the wrong part in the box.
luc
Paso Robles CA
I bet you that the problem was that the A/C (snowflake symbol) position was missing.
Well, it's not missing nor a wrong part in the box.
They just put a dot of the same material than the display over it to cover it.
You just have to remove/peel it of.
Why do they do that?
Very simple, the ACR dit not have A/C ( you could add it back as an option) and therefore they could use the same # part for car with and without A/C
Kevsmu4
