Thread: backyard buddy 4 post lift for sale
Reply to Thread
Results 1 to 30 of 30
  1. #1
    Default backyard buddy 4 post lift for sale
    backyard buddy 4 post lift - ViperClub Classifieds
    i just listed my backyard buddy lift that i just purchased in december in the classified section. i am buying a new house and cannot take the lift with me unfortunatly. look at the thread (my christmas gift to my viper) to look at the photos. i am asking $2500.00. i will not take the lift apart to ship it. i brought the lift to my house in one piece by a flat bed tow truck.
  2. #2
    Join Date
    Aug 2005
    Sterling, VA
    Default Re: backyard buddy 4 post lift for sale
    Good luck with the sale. Please wait until your ad is approved next time so that you can include the required link in your post. Thanks.
  3. #3
    Join Date
    Oct 2008
    Southshore, MA
    That is exactly what I am looking for, too bad I no longer live in NE Ohio. I contacted Backyard Buddy few months ago and their leadtime back then was 12 weeks. Good deal. GLWS.
  4. #4
    Join Date
    Jan 2008
    Whats the Height and width of the Lift?
  5. #5
    From the floor to the top of the posts is 6'9" and from outside to outside of the feet is 9' 2-1/2" wide
  6. #6
    here is how i got it home
  7. #7
    Northeast
    Mopar Steve's Avatar
    Join Date
    Oct 2000
    Newark DE
    Disassembly is not that tough for whoever buys it, and that will be necessary because it wont fit through many garage door already assembled.
  8. #8
    Join Date
    May 2007
    Zanesfield, Ohio
    Was looking to buy one in the next few months. (new garage isn't up yet)
    If taken apart i could sore it off site.
    Anyways what's your current garage inside height?
    Do they sell caster kits for this lift?
  9. #9
    My garage height now is 9'8" and yes they do make a caster wheel kit for it. You would have to drill holes in the posts to get the backyard buddy wheel kit to work. I do have a set of caster wheels I made work that are for a danmar lift I could let you borrow to move the lift but I need the wheels back
  10. #10
    Join Date
    May 2007
    Zanesfield, Ohio
    Quote Originally Posted by QUICKSRT10/SRT8 View Post
    Yea I'd have to get a caster kit so i could move it in the summer when it's not in use.
    How high does this lift go? I'm planning on going with a 10'-0" plate height with a scissor truss. Viper will probably be parked on top since it's a shorter car and my mustang on the bottom.
  11. #11
    Right now the lift is on the 9th safety notch out of 10 and I have about 6 inches from the top of my car to the ceiling in the garage. With the lift all the way up you will have 63" of clearance under it
  12. #12
    Just lowered the price to $2200
  13. #13
    Join Date
    Oct 2006
    Laplata, Maryland
    Quote Originally Posted by Mopar Steve View Post
    No
    Fully assembled, It will easily fit through any standard 9' wide garage doors.
    The 9'2" overall width is from the outside of the bottom leg pad to the outside of the other pad.
    The width from outside of 1 runway to the outside of the opposite runway is 79".
    Move it into the garage at a slight angle. Insert one column, straighten, then the other, move forward, then repeat.
    This is a smokin deal, I have 2 BYB lifts....
    Good luck with your sale....
  14. #14
    Join Date
    Oct 2006
    Laplata, Maryland
    Don't sell yourself short, correct, from the bottom of the runway to the floor is like 63". but from the top of the runway (where the tires sit) is 67", then once it up in the air and you're under it, the bottom of the car is much higher. At 6', I could walk under my Pantera, never tried it with my Viper but it should be similar.
    Good luck....
  15. #15
    Midsouth
    Chuck 98 RT/10's Avatar
    Join Date
    Oct 2000
    tampa, fl USA
    If it is still for sale when the winter thaws I'll drive up and get it.
    Chuck 98 RT/10
    BabelMotorsports.net
    SAFEMotorsports.com
  16. #16
    Join Date
    May 2007
    Zanesfield, Ohio
    Quote Originally Posted by johnk View Post
    No
    What is it post to post, not flange?
  17. #17
    Join Date
    Jun 2004
    Jupiter, FL
    pm sent. I would take it right now, if I could figure a way to get it down here. My doors are high enough to roll it right in. Im just not sure who could transport, cost effectively.
  18. #18
    Join Date
    Oct 2006
    Laplata, Maryland
    Quote Originally Posted by lagalaxy13 View Post
    Their standard lifts are 8' 4" outside post to outside post.
    But if you're worried about moving the assembled unit into a garage, the post-to-post measurement doesn't come into play, just the overall max width (outside pad-to-pad) and runway width.
  19. #19
    Join Date
    May 2007
    Zanesfield, Ohio
    Well if he doesn't sell it soon, I'll try to get it. I have a truck I can haul it in apart but not a trailer that can hold it.
  20. #20
    Northeast
    Join Date
    Oct 2000
    Newark DE
    Most doors are just seven feet or less. The uprights wont fit through many doors. (vertical)
  21. #21
    This is as low as I can go now $2000
  22. #22
    Join Date
    Apr 2008
    "OIHO"
    BYB are great lifts!! I have one for my snakes and I love it. It's listed at a great price as well. You will not find another BYB at that price. Get it before it's gone.
  23. #23
    Join Date
    Oct 2006
    Laplata, Maryland
    Yes it will. (when using a standard 7' height door)
    7' = 84" ...Floor to top of the cable adjusting bolts on each column is 82.25". You can gain an additional 2" (80.25" overall height) by partially or fully removing the cable adjusting bolts as those columns pass under the door.
    Many doors may hang down a little, providing less than the full 7' height, just disconnect the garage door opener (if used) and slide the door up so that the full height is available.
    It would probably easilly even go through a door with a 6.5' high opening or less, might have to raise the oposite end a little to duck the respective columns through the door.
  24. #24
    Midsouth
    Join Date
    Oct 2000
    tampa, fl USA
    Hmmm...about 2200 miles for me...18 hour drive dry, how much snow do you guys have up there?
    How long does it take to disassemble it?
    Chuck 98 RT/10
    SAFEMotorsports.com
  25. #25
    Join Date
    Feb 2010
    Chattanooga, TN
    If you were closer, I'd be all over it. I don't even want to think about what it would cost to transport that thing down here assembled.
  26. #26
    Join Date
    Apr 2008
    "OIHO"
    Quote Originally Posted by Chuck 98 RT/10 View Post
    We have about six inches on the ground but the roads are pretty clear as of last night. When I got my BYB I had them install it and from the time they showed up to the time they were helping me get my car on the lift it was less then 90 min. Now, you have to consider the fact that the guy (and gal) that did this has been doing it for a long time and they had a very good system worked out to do this job quickly.
  27. #27
    Join Date
    Apr 2008
    "OIHO"
    ^^^^I stand corrected. We have more like 8 to 10 inches on the ground. Thats whats on my deck.
  28. #28
    Finally the lift just sold for $2000!!!!! A guy just drove up from Michigan and took it with him
  29. #29
    Midsouth
    Join Date
    Oct 2000
    tampa, fl USA
    Good for you. I wasn't looking forward to the drive anyway.
    Chuck 98 RT/10
    SAFEMotorsports.com
  30. #30
    Join Date
    Apr 2008
    "OIHO"
    Congrads on the sale.
  1. Replies: 3
    Last Post: 05-03-2009, 10:25 AM
  2. Any Gen3 owners have a BackYard Buddy Lift?
    By johnk in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 01-15-2007, 01:11 PM
  3. Backyard Buddy Lifts
    By FASTFUN in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 07-12-2005, 07:30 PM
  4. 4 Post Lift Discount - Rotary Revolution Lift
    By Jerry Dobson in forum RT/10 and GTS Discussions
    Last Post: 07-30-2004, 01:46 PM
  5. Backyard Buddy or Cytech Double Park???
    By larry milo in forum RT/10 and GTS Discussions
    Last Post: 07-16-2003, 03:07 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
