Thread: Gen 3 and Gen 4 difference
Reply to Thread
Results 1 to 19 of 19
  1. #1
    Join Date
    Jun 2006
    Sweden
    Age
    50
    Default Gen 3 and Gen 4 difference
    Is there any difference between the Gen3 and Gen4.
    Thought interior and exterior except the hood?
    Fits bump / fender from Gen3 to gen4?
  2. #2
    Gateway
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    Default Re: Gen 3 and Gen 4 difference
    In my opinion, they are quite different driving experiences !!!
    Engine, tranny, tires...a world apart when comparing stock, out-of-the-box Vipers.
    To me, the interior is only the location where I plant my arse when driving the Asps. I am happy with the general fit, finish, paint, color, etc...admitting that others pay much more attention to same than I do.
  3. #3
    Join Date
    May 2008
    Gen 3 feels like a dump truck hit you off the line and continues to accelerate at an above average pace.
    Gen 4 feels like a lttle slower off the line, Then you hit 3000 rpm and you will be scared for your life.
  4. #4
    Join Date
    Nov 2009
    Bay Area California
    Quote Originally Posted by Garron View Post
    great little analogy..
  5. #5
    Join Date
    Feb 2007
    LA, CA
    Gen 4 has:
    Vented Hood
    Electric cooling fan
    New Engine
    Venom engine control
    TLEV emissions
    Double disc clutch
    New T6060 Transmission
    New differential
    New tires
  6. #6
    Join Date
    Oct 2008
    Adamsville, TN
    Age
    39
    Quote Originally Posted by DC Performance View Post
    Gen 4 has:
    Vented Hood
    New Engine
    TLEV emissions
    Double disc clutch
    New differential
    New tires
    Whoop there it is
  7. #7
    viperbilliam's Avatar
    Join Date
    May 2005
    Richland, WA
    Gen III cooling fan isn't electric?
    2005 Commemorative Edition (sold); other hot rod; 2010 Chrys 300SRT8. Three bikes - 97 Harley Superglide, 09 Harley Softail Night Train, & 1199R Ducati.
  8. #8
    Join Date
    Sep 2009
    Quote Originally Posted by viperbilliam View Post
    We have a fan clutch too?
  9. #9
    Join Date
    May 2005
    Richland, WA
    Quote Originally Posted by 10 BANGER View Post
    According to Dan at DC above, we just might have that ugly fan clutch somewhere - I'll look under the hood tomorrow to make sure! I could swear we don't but I'm too old to swear on my memory.
  10. #10
    Join Date
    Dec 2007
    Knoxville, TN
    Nope, its run off of the ps pump.
  11. #11
    Join Date
    Nov 2007
    So, basicly, their saying the body panels and interior are pretty much the same. I do know they upgraded that plastic door sweep that is so easy to break on the GenIII. But you can't tell the difference just to look at it.
  12. #12
    West
    Paul Hawker's Avatar
    Join Date
    Oct 2000
    San Diego, Calif, USA
    The driving experience is a little bit different on the 08+
    Transmission shifts much smoother with greater feeling for precision when selecting gears.
    Rides smoother and handles better due to non run-flat tires.
    Engine pulls much stronger at higher revs.
    New rear end pulls smoother off the corners. Seems to track better, and more consitantly with better placement.
    A bit more refined car, also some improvement on build quality.
    Some notice a lag from the throttle by wire, and prefer the previous throttle cable.
    The extra 95 hp shows up at both road courses. On the drag strip it changes from a low 12 second car, to a high 11 second car in most hands.
    08+Vipers have a smooth idle, very little neutral gear rattle, and a nice rush of power above 3,500 rpm where previous models tended to flatten out.
    New hood design removes more engine heat and prevents pressure from building up underneath the car. This reduces lift, and makes the car more stable at higher speeds. In addition, where earlier verts had heat swirling into the interior around the A pillars, the new hood allows for much cooler interiors with the windows open for city driving.
    Paul Hawker, San Diego
    Baby you can drive my car,
    beep beep, beep beep YEA!
    VCA # 05669
  13. #13
    Join Date
    Jun 2006
    Sweden
    Age
    50
    Thank you for all answer
  14. #14
    Join Date
    Nov 2007
    Greenwood Village, CO
    One more thing, the Gen 3s are generally easier to modify than Gen 4s. The Gen 4 Venom controller (PCM) is a lot more sensitive to mods and will often throw an engine code if you try to mod the engine in any way. Many people replace the stock PCM with the Mopar controller and, though not technically street legal, the Mopar controller will not throw engine codes as readily as the stock Gen 4 PCM. However, since it does not perform all the on-board emission tests you may have trouble getting your car inspected in some states.
    The Gen 3s handle mods very well and there are many heavily modded examples driving around. My own Gen 3 is supercharged (and in the classifieds by the way).
  15. #15
    Join Date
    Dec 2005
    Edmonton, Canada
    My convo with a DCX engineer a few months ago (slightly redacted to leave out names and unrelated info):
    Hey XXXXX
    The production powertrain and chassis of the 2003 and 2006 cars are basically the same. There were small improvements/refinements made during that time, but no major spec changes.
    The 2008 car is considerably different. There were a ton of improvements ranging from small fit/finish and NVH kinds of things to the following major changes:
    - Much improved clutch pedal effort (new dual-disk clutch w/more torque capacity)
    - Much improved shift efforts in the new TR6060 trans
    - Much improved limited slip diff (no more one-wheel peel coming off corners during hard track sessions)
    - New 600 HP Gen IV engine (vs 510 HP Gen III)
    - Improved ride/handling (new springs/dampers and non-run-flat PS2 tires).
    With the 2008 cars, it is possible to get a nice HP boost with some exhaust mod's and relatively inexpensive MOPAR cal (I think near 640 HP; XXXXXX could give you more details).
    If XXXXXX is going to go nuts modifying the powertrain, there may be more options for the 2003-2006 models. First, they have been around longer. Secondly, the aftermarket has to deal with electronic throttle control and all the safety & emissions features that can lead to faults, when providing kits for 2008 cars.
  16. #16
    Join Date
    Jul 2003
    Massillon, Ohio
    I don't think anyone has mentioned the different exhaust, which is a big deal. Not having the cross over pipes under the seats helps keep the cockpit cooler and saves a little weight.
    Bill
  17. #17
    Join Date
    Jan 2009
    Shavertown, Pa.
    Quote Originally Posted by Paul Hawker View Post
    Great Info!
  18. #18
    South
    gb66gth's Avatar
    Join Date
    Dec 2007
    Big-D
    Don't forget , the GenIV has a swing arm oil pick up in the sump. Gen III, not.
    '05 Black SRT10 vert.
    '08 Black SRT10 vert.
    '66 Shelby GT350H "Rent-A-Racer"
  19. #19
    Join Date
    Jan 2011
    I qualify this response in that I have only driven my 08 a few miles due to weather. I owned an 05 for 3 years and loved it. I asked an extremely reputable shop in my area, that does work on exotics, the difference in my 05 and the 08, I now have and this was his response. He said the driveline difference was like between night and day. Engine changes, dual disc clutch, transmission difference off the charts, much better rear-end, and finally much better tires. He claimed that he has never seen changes so radically change a car with the same body. I can't wait for spring!
  1. Can you tell the difference?
    By Bobpantax in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 02-21-2009, 09:44 AM
  2. Difference between '00 & '02 GTS
    By FinalEd357 in forum RT/10 and GTS Discussions
    Last Post: 12-07-2007, 11:10 PM
  3. What a difference ........
    By wormdoggy in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 11-23-2005, 05:44 PM
  4. LOL -> see the difference!
    By ViperGTS in forum Sneaky Pete's Place
    Last Post: 11-18-2005, 08:44 AM
  5. Difference between GT 2 and GTS/R
    By jp in forum RT/10 and GTS Discussions
    Last Post: 08-14-2002, 12:26 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
