Thread: need explanation of Viper's firing order
Reply to Thread
Results 1 to 9 of 9
  1. #1
    Join Date
    Oct 2010
    Vincennes IN
    Default need explanation of Viper's firing order
    What does
    1, 10-9, 4-3, 6-5, 8-7, 2 (unequal firing 90-degree and 54-degree intervals)
    mean?
  2. #2
    Join Date
    Aug 2005
    Chandler AZ
    Default Re: need explanation of Viper's firing order
    Quote Originally Posted by jwolf View Post
    What does
    mean?
    Not sure what you are looking for exactly; but, the firing order follows the sequence:
    1,10,9,4,3,6,5,8,7,2 or what makes it easier for me to picture: 2,1,10,9,4,3,6,5,8,7 . In other words, front right, front left, rear right, rear left, etc....
    Numbering schame: Left side: front to rear...1-3-5-7-9 and Right side front to rear 2-4-6-8-10
    Here is a post that tries to explain the angle deal: http://forums.viperclub.org/2353911-post2.html
    That is the extent of my knowledge on the subject.
  3. #3
    Join Date
    Aug 2005
    Chandler AZ
    You got me wondering about where the 54 comes into the equation. Here is another thread, see post #7
    http://forums.viperclub.org/rt-10-gt...-sequence.html
  4. #4
    Join Date
    Nov 2007
    Ontario and Ohio
    Quote Originally Posted by AZTVR View Post
    Now I am confuzzled!
  5. #5
    Join Date
    Nov 2007
    Ontario and Ohio
    What does
    mean?
    Means it is a 90 deg block, but due to needing to fire all 10 banks in 720 deg (2 revolutions of the motor), they needed to get the pistoms firing at odd intervals - One at 90 deg, and the other at 54.
    If they all fired at 90 deg, then they would have 900 deg total revolutions for all 10 to have fired. Does not work.
  6. #6
    Join Date
    Jul 2008
    Metropolis
    It's a V-10, four stroke. The engine math is a but strange if you're used to a V-8.
  7. #7
    Join Date
    Oct 2010
    Vincennes IN
    Quote Originally Posted by jdeft1 View Post
    Does 1,10-9,4-3,6-5,8-7,2 mean the same as
    1,10,9,4,3,6,5,8-7,2
    or does it mean the 10 and 9 fire at the same time?
    or at the same time every other revolution? (alternating a power and a waist spark))
  8. #8
    Join Date
    Aug 2005
    Sterling, VA
    Age
    45
    Each piston fires once every 2 rotations, or 720 degrees.
    In this scenario: 1, 10-9, 4-3, 6-5, 8-7, 2
    comma = 90 degrees
    dash = 54 degrees
    Fire 1, rotate 90
    Fire 10, rotate 54
    Fire 9, rotate 90
    Fire 4, rotate 54
    Fire 3, rotate 90
    Fire 6, rotate 54
    Fire 5, rotate 90
    Fire 8, rotate 54
    Fire 7, rotate 90
    Fire 2, rotate 54
    Tot. Degrees: 720
  9. #9
    Join Date
    Oct 2010
    Vincennes IN
    Quote Originally Posted by kcobean View Post
    comma = 90 degrees
    dash = 54 degrees
    Fire 1, rotate 90
    Fire 10, rotate 54
    Fire 9, rotate 90
    Fire 4, rotate 54
    Fire 3, rotate 90
    Fire 6, rotate 54
    Fire 5, rotate 90
    Fire 8, rotate 54
    Fire 7, rotate 90
    Fire 2, rotate 54
    Tot. Degrees: 720
    Thanks, that is what I was asking.
  1. Gen III cyl firing order?
    By Joseph Dell in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 02-12-2005, 09:42 PM
  2. Firing order pic.
    By BUD in forum RT/10 and GTS Discussions
    Last Post: 09-26-2002, 07:53 PM
  3. QUICK!!! Firing order for 96 RT
    By MadMaxx in forum RT/10 and GTS Discussions
    Last Post: 06-21-2002, 03:26 PM
  4. firing order.......help !
    By Robert1994 in forum RT/10 and GTS Discussions
    Last Post: 11-06-2001, 12:12 AM
  5. Firing order help!
    By MES in forum Archive Management
    Last Post: 04-15-2001, 03:18 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
