need explanation of Viper's firing order
jwolf
Vincennes IN
What does
1, 10-9, 4-3, 6-5, 8-7, 2 (unequal firing 90-degree and 54-degree intervals)
mean?
AZTVR
Chandler AZ
What does
mean?
Not sure what you are looking for exactly; but, the firing order follows the sequence:
1,10,9,4,3,6,5,8,7,2 or what makes it easier for me to picture: 2,1,10,9,4,3,6,5,8,7 . In other words, front right, front left, rear right, rear left, etc....
Numbering schame: Left side: front to rear...1-3-5-7-9 and Right side front to rear 2-4-6-8-10
Here is a post that tries to explain the angle deal: http://forums.viperclub.org/2353911-post2.html
That is the extent of my knowledge on the subject.
Mopar Boy
Ontario and Ohio
What does
mean?
Means it is a 90 deg block, but due to needing to fire all 10 banks in 720 deg (2 revolutions of the motor), they needed to get the pistoms firing at odd intervals - One at 90 deg, and the other at 54.
If they all fired at 90 deg, then they would have 900 deg total revolutions for all 10 to have fired. Does not work.
jdeft1
Metropolis
It's a V-10, four stroke. The engine math is a but strange if you're used to a V-8.
J
jwolf
Vincennes IN
Does 1,10-9,4-3,6-5,8-7,2 mean the same as
1,10,9,4,3,6,5,8-7,2
or does it mean the 10 and 9 fire at the same time?
or at the same time every other revolution? (alternating a power and a waist spark))
kcobean
Sterling, VA
Each piston fires once every 2 rotations, or 720 degrees.
In this scenario: 1, 10-9, 4-3, 6-5, 8-7, 2
comma = 90 degrees
dash = 54 degrees
Fire 1, rotate 90
Fire 10, rotate 54
Fire 9, rotate 90
Fire 4, rotate 54
Fire 3, rotate 90
Fire 6, rotate 54
Fire 5, rotate 90
Fire 8, rotate 54
Fire 7, rotate 90
Fire 2, rotate 54
Tot. Degrees: 720
J
jwolf
Vincennes IN
comma = 90 degrees
dash = 54 degrees
Fire 1, rotate 90
Fire 10, rotate 54
Fire 9, rotate 90
Fire 4, rotate 54
Fire 3, rotate 90
Fire 6, rotate 54
Fire 5, rotate 90
Fire 8, rotate 54
Fire 7, rotate 90
Fire 2, rotate 54
Tot. Degrees: 720
Thanks, that is what I was asking.
