Thread: Differential Fluid Change
Reply to Thread
Results 1 to 19 of 19
  1. #1
    Join Date
    Jun 2010
    San Antonio, TX
    Default Differential Fluid Change
    I was going to drain and refill the rear diff with Mobil1 75w-140. It is listed to contain limited slip additives but also notes factory additives can be added. SO should I still add in the Mopar lsd additive or will just the Mobil1 fill be okay? I couldn't find a good answer after searching.
  2. #2
    Join Date
    Mar 2010
    In a Tennessee hollow!
    Default Re: Differential Fluid Change
    The Mopar shop guys suggested the additive too if you don't use their fluid. I think the Mopar stuff in Castrol Syntec but I put the additive in too when I changed the fluid last year. I just put in a new rear gear and used the additive on JonB's advice. He has some lube that says you don't need additivie but recommended its use with anything else. Better be safe than sorry.
  3. #3
    Join Date
    Jul 2007
    When I had a factory diff I used Mopar fluid and Mopar additive. Nothing wrong with following the recommendation from the factory.
  4. #4
    Join Date
    Dec 1997
    Quote Originally Posted by Bexar80 View Post
    I was going to drain and refill the rear diff with Mobil1 75w-90. It is listed to contain limited slip additives but also notes factory additives can be added. SO should I still add in the Mopar lsd additive or will just the Mobil1 fill be okay? I couldn't find a good answer after searching.
    The Year Matters......... I hate to risk the ASSumption that the FORUM matters!
    Gen 1-2-3 with OE diffs, REQUIRES the friction-modifier additive; Some very few oils (SynGear) has the additive included. MoPar oils (Castrol) do not.
    Gen 4 OE GKN Visco-Lok only needs additive every other change! Really...
    And diffs with Quaiffe or OSGiken do NOT require the additive/modifier.
  5. #5
    Join Date
    Jun 2003
    ALL OVER
    Age
    49
    yup, dont forget the modifier. it does name a difference. i always use the factory fill on this
  6. #6
    Join Date
    Mar 2010
    Netherlands
    I filled her up last week with the OEM products. (I have an original drain plug on my 92, you probably don't, LOL)
  7. #7
    Join Date
    Jan 2008
    Toronto, Canada
    Royal Purple here. Emailed their tech department and they said that with RP additives are not needed.
  8. #8
    Join Date
    Feb 2003
    Commerce , MI
    You may want to check the manual on the viscocity range of your differential fill. I believe the 75w-90 is for the transmission. I believe you should be using 75w - 140 for the differential ???
  9. #9
    Join Date
    Mar 2010
    Netherlands
    Quote Originally Posted by RT/ED View Post
    I think he's right, Tator told me:
    Diff: 75W-140 synthetic diff fluid [#4874469] 2 quarts and 4 oz "Limited Slip Additive" #4318060AB.
    so that's what I've putten in there.
  10. #10
    Join Date
    Jul 2007
    Quote Originally Posted by Roy View Post
    You mean you used what the factory called for???
  11. #11
    Join Date
    Mar 2010
    Netherlands
    Quote Originally Posted by dave6666 View Post
    Yep and make sure the original poster knows that the original viscosity isn't 75w90, but when he allready knows, there is no harm done I guess.
  12. #12
    Join Date
    Jun 2010
    San Antonio, TX
    Yep 75w-140, slide of hand when I was writing my post.
  13. #13
    Join Date
    Oct 2007
    DE
    Age
    35
    On the Viper I go with the factory fill w/modifier to make certain my diff is performing as designed. Wouldnt want to have a fluid that might cause her to slip to much or not enough.
    From what i understand if the diff fluid is too slippery than the limited slip will slip too much not giving you as much traction to one of the rear wheels.
    In contrast: a fluid that is not slippery enough(for example one without the friction modifier) the limited slip will not slip enough causing her to bind up and hop/slip one of the rear wheels when going around a tight turn.
    On my Dakota it calls for the same stuff but i have used the Mobil1 with a HALF bottle of the moparlimitedslipmodifier. Works fine from what i can tell. So thats what i would recommend if youve got a couple bottles of the Mobil1 stuff and want to put em to use.
  14. #14
    Join Date
    Jul 2007
    What exactly in the reason to change from the factory fill? Is there a problem that is being solved? Is something broken that need fixing? Can anyone supply supporting evidence or documentation or research or whatever that states what was bad or broken and now it's fixed or better?
  15. #15
    Join Date
    Nov 2008
    i dont run any oil in mine
  16. #16
    Join Date
    Jul 2007
    Quote Originally Posted by bluesrt View Post
    We know
  17. #17
    Join Date
    Nov 2008
    its a dry clutch set up
  18. #18
    Join Date
    Feb 2008
    Houston
    if you run a dry clutch set up
    it will eventually blow the hood off your avatar pic
  19. #19
    Join Date
    Nov 2008
    rock and roll
  1. Differential Fluid Replacement
    By JeffTheViperMan in forum RT/10 and GTS Discussions
    Last Post: 12-18-2008, 11:20 AM
  2. Question: Differential fluid in the morning
    By Viperfreak2 in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 01-20-2004, 07:57 AM
  3. Differential Fluid?
    By slaughterj in forum RT/10 and GTS Discussions
    Last Post: 08-30-2003, 01:55 AM
  4. Differential Fluid - How to change?
    Last Post: 08-05-2003, 01:58 PM
  5. 94 Differential Fluid Change
    By JonB in forum Archive Management
    Last Post: 04-13-2001, 09:56 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
