Thread: Using NOS to overcome very high DA
Reply to Thread
Results 1 to 7 of 7
  1. #1
    Join Date
    Aug 2006
    Las Cruces, NM
    Age
    33
    Default Using NOS to overcome very high DA
    Hi all, I was hoping some of forum the gear heads could give me their takes on the possibility of using a 100-150 shot of NOS on a Gen 4 to overcome the very high DA here.
    The elevation of the nearest strip is 3900 feet, and after that, it's 4200 feet. Since I'm out in the desert, the temps are typically 80-90 degrees at night. Using various calculators, I get DAs of 6000-7000 feet. In practice, this has equated to times in the 12's, with trap speeds varying from 117 to 119.
    I read the thread about the car's PCM powering down the car after a shift on NOS, which begs the question: is this happening because the air/fuel characteristics with the NOS is throwing the PCM off, or because of something related to the car making so much more power? If it's the first, then I'm probably screwed, but if it's the second, a 100 shot of NOS would only be taking me up to the car's rated horsepower at sea level (by my estimates I'm losing about 90 horsepower to the low density air.)
    Does anyone have any thoughts? Thanks.
  2. #2
    Join Date
    Jun 2003
    ALL OVER
    Age
    49
    Default Re: Using NOS to overcome very high DA
    Nitrous and gen4 doesn't work well together I believe. Pretty sure the pcm will shut down on activation. But I'm sure with a boatload of money it can be tuned to work
  3. #3
    I always felt bad for the guys running at Bandamiere (sp?). Density Altitude at it's worst, good luck.
  4. #4
    Join Date
    Oct 2007
    You know you have a fast stocker when your at a DA of 7000 and still can trap around 120 mph
  5. #5
    Join Date
    Aug 2006
    Las Cruces, NM
    Age
    33
    Quote Originally Posted by Twister View Post
    Yeah haha, it's pretty humorous showing up and seeing a C6 corvette run high 13's/low 14's. However, it's galling to see turbocharged ricemobiles doing so well. I was rather hoping NOS would regain some of that lost horsepower for me.
    plumcrazy, it was my understanding that what was happening was that the PCM would kill the car's power after an upshift with NOS installed. What I'm wondering is if this would be mitigated by the fact that I'd be using NOS to get my car air with oxygen density similar to sea level.
  6. #6
    Join Date
    Jun 2003
    ALL OVER
    Age
    49
    good point, i certainly dont know. id get a hold of dan at viper specialty. he seem to know a lot about this kinda stuff with the gen4
  7. #7
    Join Date
    Oct 2007
    Couldnt adding..
    headers
    manifold
    tune
    yield 40 rwhp and get you around 120-124 mph trapps?
    Im always weary on putting nos on these srt10 or z06 engines. Good friend of mine just blew up his c6Z06 engine after useing NOS about 5 times.
    Good luck
  1. High Quality/High Resolution Pictures
    By JeremyS in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 03-13-2007, 10:25 AM
  2. NayKid Racing Looks to Overcome Weight Penalty with Strong SCCA Runoffs
    By Jay Herbert in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 10-07-2006, 09:50 AM
  3. high mileage Vipers. How high is still OK
    By bronco4x440 in forum RT/10 and GTS Discussions
    Last Post: 09-21-2003, 08:04 PM
  4. The latest High School "High", also potentially deadly:(
    By VIPERESS in forum Sneaky Pete's Place
    Last Post: 10-26-2002, 09:18 AM
  5. The biggest hurtle to overcome when buying a Viper
    By Toby in forum Sneaky Pete's Place
    Last Post: 03-06-2002, 05:11 PM
Tags for this Thread
View Tag Cloud
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
