Thread: Need help findind fuel pump wire off ECU or fuse box
Reply to Thread
Results 1 to 2 of 2
  1. #1
    Join Date
    Apr 2011
    Default Need help finding fuel pump wire off ECU or fuse box
    I want to hook the trigger wire for my water pump, secondary fuel pump and water injection pump to the fuel pump power source. I feel like an idiot for not running a wire right off the fuel module while I was in there, but I don't want to pull the top back and drill out the rivets to get to it now. I have run a wire up to the engine bay. Can somebody with a wiring schematic tell me which wire off either the fuse box or the ECU I should tap into? Thanks in advance!
    Colby
  2. #2
    Join Date
    Apr 2011
    Default Re: Need help findind fuel pump wire off ECU or fuse box
    If you call Tuesday am. I'll fax it over for you. Mike 951-461-VIPR (8477)
  1. Fuel pump fuse/relay location?
    By Bandit3 in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 10-22-2009, 11:44 AM
  2. Fuel Pump Fuse Question
    By ViperTony in forum RT/10 and GTS Discussions
    Last Post: 06-18-2008, 04:05 PM
  3. Fuse Tap, Wire Tap..Super clean power out for your Viper
    By DAMN YANKEE in forum RT/10 and GTS Discussions
    Last Post: 02-11-2007, 12:19 PM
  4. fuel pump does not come on after MSD Fuel Pump Voltage Booster
    By vegasviper in forum RT/10 and GTS Discussions
    Last Post: 10-29-2006, 08:16 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
