Thread: Burning plasic smell and smoke out exhaust pipes
Reply to Thread
Results 1 to 9 of 9
  1. #1
    Join Date
    Aug 2001
    SUNNYVALE,CALIF.
    Default Burning plasic smell and smoke out exhaust pipes
    I started my Viper up and saw lots of white smoke coming out the exhaust with a burning plastic smell, and turned it off, and noticed coolant under the car as well? It does not smell like oily smoke, so I am assuimng coolant is getting into my intake, or cylinders? Hopefully my Viper tech will come by and look at it today? Any ideas?
  2. #2
    Join Date
    Oct 2007
    DE
    Default
    What year? If 96-99 you might be due for a timingcover gasket. Get her done quick as the motors internals do Not like to be marinating in coolant.
  3. #3
    Join Date
    Aug 2001
    Saratoga, CA, USA
    Default Re: Burning plasic smell and smoke out exhaust pipes
    Dennis,
    Did you see the water on the ground before you started the car?
    I'm thinking, you might have had water in one or more cylinder and it was sent down the pipes at start up. Then leaked out onto the ground.
    Are you still S/C with water injection? might be leaking.
    Hope your tech finds it a simple fix.
  4. #4
    Gateway
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    My GUESS is cracked head or blown head gasket.
    I don't do "PM's" and I NEVER read "visitor messages" since I prefer DIRECT communication.
  5. #5
    Join Date
    Jul 2010
    davenport iowa
    burnt plastic smell i have that problem ,, mine was a master card this Christmas. good luck with your repair
  6. #6
    Join Date
    Aug 2001
    SUNNYVALE,CALIF.
    My car is a 2001 and I am normally aspirated now. No super charger any more. Plus coolant was under the right side of the engine area. Not a lot, probably about 3 ozs. on the ground.
  7. #7
    Join Date
    Jul 2003
    GA
    Put it in the air and check the front cover and head gasket area to see where its leaking from. Ouch, hope its something simple but it doesn't sound happy.....
  8. #8
    Join Date
    Nov 2000
    NE Ohio
    If it is getting into the intake and out the exhaust it probably is not the front cover, as Steve said, the head gasket is likely.
  9. #9
    Join Date
    Aug 2001
    SUNNYVALE,CALIF.
    Thanks for all of the input. Tech has not been able to come by becasue of Christmas, but I am in no hurry since it is winter time, and i only take the car out every two weeks to keep it fresh.
  1. burning smell when WOT
    By Warfang in forum RT/10 and GTS Discussions
    Last Post: 02-21-2009, 11:34 AM
  2. burning smell at WOT
    Last Post: 08-10-2007, 09:27 AM
  3. Another one of those I smell something burning threads...
    By Blue Batmobile in forum RT/10 and GTS Discussions
    Last Post: 05-31-2006, 02:40 AM
  4. burning smell?????
    By jimandela in forum RT/10 and GTS Discussions
    Last Post: 08-11-2001, 12:14 AM
  5. Burning plastic smell?
    By 99t1 in forum Archive Management
    Last Post: 04-07-2001, 11:23 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
