Thread: Got a 2004 with a problem
Reply to Thread
Results 1 to 17 of 17
  1. #1
    Join Date
    Jan 2012
    Vail Arizona
    Default Got a 2004 with a problem
    Title is a little misleading. My son who is in Afghanistan got a Viper and sent it to me to take care of till he gets back. The Car only has 5,200 miles and looks brand new.
    My problem is that I went to register it and had to get an emissions test done. The car had a check engine light on it. It failed for a gas cap being bad. Got a new gas cap and disconnected the battery for 20 minutes to reset the computer. Went in for another emission test and failed because computer wasn't working yet. Read the owners manual and found that the if you turn the check key on (but don't start) after 15 seconds the check engine light will flash if the computer hasn't reset. Well I drove it on the highway yesterday for 100 miles. Drove around town for 30 miles and it still hadn't reset. Today after reading the forum I drove down the highway 25 mile and back 25 miles keeping the speed between 50 and 60. The computer still isn't reset. I am going to wait a few hours for it to cool off then check it again.
    After reading a lot today on the subject it appears that I will need to perform the correct Driving cycles to get it to reset. Does anyone know what the Driving Cycles for a Viper is??
    I have 3 days to get the car tagged before the temp tag from another state expires.
  2. #2
    Join Date
    Dec 2010
    Fort Worth
    Default Re: Got a 2004 with a problem
    Got no help for you...but she's a beauty!
  3. #3
    Join Date
    Oct 2011
    vancouver, bc
    get a sct to check for the codes. it will tell you what is exactly wrong and you can also reset the pcm.
    gd luck
  4. #4
    Join Date
    Oct 2004
    SoCal
    Call Dan Craigin at DC Performance, he'll have the answer for you.
  5. #5
    Join Date
    Jan 2011
    Spring Hill, FL
    Should be able to bring it to any autozone and have them clear the codes off for you. Or buy your son an SCT tuner as a surprise, and clear them yourself. I got mine brand new on flea bay for $200.
  6. #6
    Join Date
    Jan 2012
    Vail Arizona
    Quote Originally Posted by DeceptioN View Post
    The codes are clear, its just getting the computer to recognize everything and say it is good that is the problem.
  7. #7
    Join Date
    Nov 2008
    start the car cold with all functions off, dont move car -let run for 15 minutes, shut off car and let sit for 10 minutes- this will set 1 cycle- next drive the car on hiway without stopping for 1 hour- you should be good after this- do not drive above 60 mph or under 55 mph
  8. #8
    Join Date
    Jan 2012
    Vail Arizona
    Quote Originally Posted by bluesrt View Post
    Car is running in garage now. put 200 mile on it yesterday. Will get on the highway today and drive for an hour for an hour between 55 and 60 without stopping. I did 25 miles down, stopped and turned around and did it again. maybe my stopping messed it up.. I have tried everything else.
  9. #9
    Join Date
    May 2008
    Hey
    All vehicles have a list of "monitors" that all modern vehicles run as they are driving. Here is a general example of what the vehicle is checking when driving.
    OBD2 MONITORS
    Misfire (continuous)
    �� Fuel Trim (continuous)
    �� Comprehensive Components (continuous)
    �� Catalyst (CAT)
    �� Exhaust Gas Recirculation (EGR)
    �� Evaporative (EVAP)
    �� Oxygen (O2) Sensor
    �� Secondary Air
    �� Heated Catalyst
    �� O2 Sensor Heater
    When you leave the key forward (engine not running and the engine light is flashing (after 15 seconds) it means the car has checked everything and it has passed. (does not mean the computer was "reset") There is a certain order for the monitors to run, example an oxygen sensor is checked before a catalyst because that sensor is used to check the catalyst.
    Monitors are checked at different loads and speeds, this information is vehicle specific. "Generally" most are checked at light loads at speeds above 25mph.
    If I had to guess the "evap monitor" is the one giving you problems, it needs an ambient temperature above a centain amount (I think most Chrysler vehicles are set around 40F) Also it will not run the test if you have below 15% fuel or above 85% fuel in the tank.
    If the battey does not go dead or the codes have not been cleared the informtion of the last pass would have been saved and this would not have been a problem.
    Honestly I would wait for summer, I can run all the monitors in 15 mintues on a Chrysler/Dodge with a normal highway drive.
    Garrett
  10. #10
    Join Date
    Jan 2012
    Vail Arizona
    Well I guess the computer is working. After the 15 minute idle the check engine light came on. cuss
  11. #11
    Join Date
    May 2008
    Do you know the code? Is it a leak or switch fault?
  12. #12
    Join Date
    Jan 2012
    Vail Arizona
    Quote Originally Posted by Garron View Post
    gas cap, again. Paid to have a smoke test done (pressurization leaK) Turns out the gas cap I bought from autozone is bad. Will get one from the dealer tomorrow.
    feelin pretty dumb and wore out
  13. #13
    Join Date
    Jul 2011
    Quote Originally Posted by Chiefc View Post
    Same thing happened to me over the summer. I replaced for factory cap with a lock cap from Autozone. Everything was fine for three weeks until I noticed the engine check light came on. I put the oringinal cap back on and the engine check light went out
  14. #14
    Join Date
    Nov 2008
    yes only a factory cap will work- period
  15. #15
    Join Date
    Dec 1997
    Columbia River Gorge
    Looks like there is a 2nd thread on this same exact car / issue?
    http://forums.viperclub.org/threads/...94#post3029594
  16. #16
    Join Date
    Nov 2007
    Greenwood Village, CO
    Evap test is a pain in the butt. Follow Garron's post above. Had the same problem with my 06. Drove over 1000 miles and the test still did not run. As stated gas tank must be between 15 and 85% and ambient temp at least at a certain temp. Also has something to do with engine temps and other tests. Coolant must be below 140 degrees (I think) and then rise to above a certain temp (not sure but might be 160). Stupid test, thank you CARB. I lived in MA at the time and I later found out that the EVAP test was optional there.
  17. #17
    Join Date
    Jan 2012
    Vail Arizona
    I have the new cap installed. I have driven it three times. All codes are clear and ready except the evap. I am hoping it is just a issue of number of heat cycles. I will drive it to work until it passes this week or until I get a ticked for expired tag. I am in Arizona and the temp in the morning is around 40 and the afternoon temp in in the 60s.
  1. Cooling problem ? Heater problem ? GEN2
    By MontrealSoft in forum RT/10 and GTS Discussions
    Last Post: 08-15-2011, 01:51 AM
  2. Clutch problem on a 2004 SRT/10 help......
    By KingSRT001 in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 05-03-2008, 03:38 PM
  3. SAME HEADGASKET PROBLEM, OH [******] MY PROBLEM!!
    By carlo in forum RT/10 and GTS Discussions
    Last Post: 09-18-2004, 11:47 AM
  4. Old Problem........Now my Problem !....... Damn Head Gasket !
    By viperrt96 in forum RT/10 and GTS Discussions
    Last Post: 09-09-2004, 10:42 PM
  5. There are two 2004's on e-bay................
    By 1TONY1 in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 09-16-2003, 12:21 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
