Thread: Transmission Gear Oil - Interesting Report
Reply to Thread
Results 1 to 15 of 15
  1. #1
    Join Date
    Nov 2000
    NE Ohio
    Default Transmission Gear Oil - Interesting Report
    A fiend just sent me an interesting report on testing different gear (transmission) oils. If this report has already been discussed, I apologize. I was just going to file it, however, I saw it included the Mopar synthetic oil we use in our transmissions. I have used the Mopar synthetic product for over ten years, but, this test report does not rank it very high.
    If you do want to waste time, just go to the results. Page 19.
    Study of Automotive Gear Lubes.pdf
  2. #2
    Join Date
    May 2011
    Seguin, TX
    Default Re: Transmission Gear Oil - Interesting Report
    I did note a couple of things:
    a). The test was done by and for the Amsoil Drive-train Division. The winner was Amsoil. I'd like to see additional unbiased objective reports performed by an outside testing firm with no close tied association to Amsoil, before formulating a concrete opinion.
    b). The test was accomplished in 2007. A lot has changed between then and now. I'd like to see a more recent study.
    But, this report does bring up interesting questions pursuant proper lubrication issues relevant drive-trains in high performance vehicles. It is certainly thought provoking.
    Thanks for posting.
  3. #3
    Gateway
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    Thanks, Jack...interesting info.
    As I see it, this seems to have been done by Amsoil (AMSOIL Drivetrain
    Division
    September 2007 AMSOIL INC.) as printed on the front page. This DOES NOT
    appear to have been done by an independent testing lab...nor is it coming from a
    peer reviewed professional journal as far as I can tell. It could all be
    true...but it still smells like "fish oil" to me, thereby undermining the
    credibility of the "study" (advertisement???)
    Mopar product studied was "Mopar Synthetic 75W-90 with Mopar LS
    additive"...which has NOTHING to do with Vipers !!!
    Still, an interesting read...THANKS !!!
    I don't do "PM's" and I NEVER read "visitor messages" since I prefer DIRECT communication.
  4. #4
    Join Date
    Oct 2007
    DE
    Quote Originally Posted by Jack B View Post
    That is exactly what amsoils marketing department wants you to do. Skip to the results that show our product is the best. Nevermind that the above tests might not be accurately testing the product for the specific app it is supposed to be used for.
    Our Fluids guru Tom has never mentioned Amsoil except but this one time commenting on how one of their tests that is bragged about in marketing dosnt even apply to the application it is used for.
    Quote Originally Posted by Tom, F&L GoR View Post
    No, I am not saying RP is not worth the money, maybe they have the best oil. It's that an independent arbitration has found they aren't 100% accurate in what they say about the performance of their product. Castrol had the silly TV ads with engines on dynos that ran until they drained the oil out (only the Castrol engine kept going), Amsoil does all the 4-Ball testing (which doesn't apply to engine oils) vs. competitors (except Amsoil does best), Quaker has the ghostly horses run next to your car and says you get power and so on. They all push the limits of marketing. The fact is that they are more the same than they are different, because the physics of lubrication says you cannot get more than a few horsepower difference between any of them.
  5. #5
    Join Date
    Feb 2011
    I wouldn't trust amzoil at all, their products don't perform as advertised, I don't want to stereotype them, but I've personally caught some of their employees being totally dishonest, personally I can't trust them anymore.
  6. #6
    Join Date
    Oct 2011
    There most likely is not that much different between the oils.........the #1 problem with the oil in the transmission or rear differential is lack of maintenance and #2 is not repairing a leak...even the smallest of leaks will come back to bite you, fluid gets low over time…temps rise or lack of lube=failure. You will probably never have a failure due to an oil issue if you use any of these oils or whatever oil you choose....your failure will be driver driving habits related
    Clint
    1997 GTS
  7. #7
    Join Date
    Nov 2000
    NE Ohio
    Quote Originally Posted by Steve-Indy View Post
    Division
    I took the Mopar oil description to mean the 75-90W used in the T56 since 2000?
  8. #8
    Gateway
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    Jack, I see your point...as I took it to mean that tested lube was to be used in differential (Vipers use Mopar 75W-140 plus limited slip juice) and not tranny (which from 1999 through 2006 used 75W-85) !! Who Knows !!!!
    Even good science and/or tests, if presented poorly, can be very concerning to anyone familiar with scientific methods and publications.
  9. #9
    Join Date
    Nov 2009
    Ponchatoula, La
    Thanks for the post. I talked with a person in the Tremeck Transmission Booth @ a car show last year & he told me the best oil to use in my 06 transmission was Mobil One Syn. ATF Fluid. Anyone use this ?
    Mid-South Vice President
  10. #10
    Join Date
    Nov 2000
    NE Ohio
    The Mopar truck gear lube and the T56 gear lube are 75-95, I have four quarts on my shelf. I doubt Mopar has two types of synthetic 75-95.
  11. #11
    Gateway
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    Jack, My point is that we are interested if VIPER fluids. A quick review of
    Viper fluid schedules from the 1992 through 2009 Service Manuals and/or CD's
    will reveal that ALL Vipers use the MOPAR "Synthetic Gear & Axle Lubricant
    SAE 75W-140 P/N 04874469AA (MS-8985)...for differential...along with MOPAR " Limited Slip Additive
    Friction Modifier" P/N 04318060AB
    MOPAR "Synthetic Gear & Axle Lubricant SAE 75W-140" 04874469 (MS-8985)
    is pictured below:
  12. #12
    Join Date
    Apr 2011
    Raleigh, NC
    Not Diff fluid...
  13. #13
    Gateway
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    You are correct...I mis-read !!
    As noted...Mopar product studied above was "Mopar Synthetic 75W-90 with Mopar LS
    additive"
    Would like to see how the Viper correct transmission fluid ..."Synthetic Manual Transmission Lubricant 75W-85" (OEM for 99-06 Vipers...plus used as a substitute in 94-98 Vipers being treated for severe NGR under TSB)
    would have compared to others.
    ) ubder TSB) un under TSB
  14. #14
    Join Date
    Nov 2000
    NE Ohio
    I read it a little closer and believe the test is diff oil. I had to reference it to the website to figure it out.
  15. #15
    Gateway
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    Thanks for your paitence, Jack. I guess that I'll never quite get over automatically assigning the term "gear oil" to use in differentials!! I must admit that if we used the Vipers in track settings, I would push harder to explore optimal fluids for specific purposes.
  1. Transmission Noise 2nd Gear
    By vincy in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 07-07-2010, 02:28 AM
  2. Transmission on Gen 2 Viper - Third Gear Grinding
    By brap in forum RT/10 and GTS Discussions
    Last Post: 04-24-2010, 12:02 PM
  3. 5th GEAR noise in my transmission.
    By steve911 in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 05-26-2009, 10:35 PM
  4. Interesting SRT-10 write up in Robb Report...
    By Y2K5SRT in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 06-15-2006, 08:51 AM
  5. Interesting Tremec Transmission specification Link...
    By Sean Roe in forum RT/10 and GTS Discussions
    Last Post: 08-03-2004, 09:14 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
