old tires
cweaver22
SoCal
I just purchased a 2005 viper with 26,000 miles on it. the rear tires are brand new but i'm not sure if the front tires have ever been replaced. there is still some life left on them but i read in another thread that old tires can be just as bad as worn tires.
is there a way to tell by the numbers on the side of the tire when they tires were manufactured?
should i replace them?
the back tires are kuhmo ecsta and the fronts are michilins, if i replace them should i get matching kuhmos?
if i keep the fronts, does having different brands in the front vs. the back matter?
CEJ
Raleigh, NC
I'd swap the Michelins for a pair of fresh Khumo's that are a match for the rear tires.
JustinB
North Texas
Check the actual age using the link above and even then I agree with CEJ, just match up the Khumo's
cowger
Just got my '05 and found '09 tires on the front and '08s on the rear. All corners have plenty of tread, but how do I tell if they are hockey pucks or still okay?
Thanks,
Bryan
jckrieger
Get Kumhos for the front. They will outperform any other tire, and match what you have in the rear. They're not terribly expensive either. I'm running the 295/35/17's.
Bill Pemberton Woodhouse
Blair,Nebraska,USA
Kumho is going away as a supplier of Viper tires, so you should check quickly with Tire Rack, VPA, etc. to see if you can grab a pair.
Otherwise the new Michelin Pilot Super Sport is out and it may pay just to get a new, full set.
Good luck.
Viper123456
