Thread: Venom badge
Reply to Thread
Results 1 to 9 of 9
  1. #1
    Join Date
    Sep 2009
    Default Venom badge
    Can some one please update my membership.
    I've sent out two PMs with no response.
    Thank you
  2. #2
    Join Date
    Apr 2005
    Default Re: Venom badge
    try emailing [email protected]. They can get you setup!
  3. #3
    Join Date
    Jul 2000
    Severna Park, Maryland
    If you are still being shown as an enthusiast and you are a paid member for 2012 then something is not matching between your membership portal and your profile here. Check to make sure your information in your profile here is complete with correct vin and VCA number. Then check the membership portal and make sure the email match here and that everything else matches. If you still have difficulty the folks at the email address can help.
  4. #4
    Join Date
    Sep 2009
    I'll check. Thanks
    Here is my renewal info.
    Member Account
    [logout]General informationName: Demoe Guerrero
    Region: Southern California
    Level: Venom
    Status: Active
    PIN: 13ED0 Join date: Apr 15th 2010
    Renew date: Feb 17th 2012
    Expire date: Dec 31st 2012
  5. #5
    Venomiss
    Guest
    VCA Member, but cannot see the full forums or missing Venom tag
    If you are a current VCA member, or a VCA Venom member and cannot view the full forums, here is how to fix that:
    1. Click "Settings" in the upper right hand corner, then click "Edit Profile".
    2. Enter your 5 digit VCA membership number there. If your VCA membership number is 345, enter 00345. If you do not know your membership number, check your name badges, or call VCA HQ for assistance.
    3. Visit the VCA membership portal at https://www.viperclub.org/membership/ and login. If you have not been there before, you will need to request a new password. Simply click the link provided and follow the directions.
    4. Once logged in, scroll to the bottom of the page, and enter your forums username and then click "Update forums". If you're a venom member, you may also select your forum badge there.
    5. If you are an officer, you will need to ensure that the email address used in the forums is the EXACT same email address used in the VCA Membership Portal. If it does not match, you will not have the access that you should have.
    Once you have completed these steps, you should have all of the correct access to the forums.
  6. #6
    Join Date
    Sep 2009
    Thank you Venomiss I will try that now.
  7. #7
    Join Date
    Sep 2009
    VOILA... FINALLY.
    You rock Venomiss.
    Thank you
    Venomiss for President.
  8. #8
    Join Date
    Sep 2009
    Sticky, sticky,, sticky, sticky
  9. #9
    Venomiss
    Guest
    You are most welcome but the list was posted originally from the awesome VCA programmer Don Boston.
    Thank you for joining as a Venom member and supporting the Viper Club of America.
  1. VENOM badge
    By 01sapphirebob in forum Board and Site Questions/Suggestions
    Last Post: 05-01-2011, 03:14 PM
  2. Venom Badge?
    By J&R3xV10 in forum Ask VCA Headquarters
    Last Post: 03-18-2010, 10:29 PM
  3. To Badge or Not To Badge?
    By NK BREKR in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 06-15-2006, 11:11 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
