Thread: KWIKLIFT Closed
Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 30 of 43
  1. #1
    Join Date
    Dec 2011
    Indy
    Age
    56
    Default KWIKLIFT Closed
    I've had a KWIKLIFT on order for almost 6 weeks and today I got a letter that they are closing and cannot fill my order. I'm pretty bummed out. I guess I'm lucky that I hadn't been charged for it yet. Now I have to start all over agin and fiqure out what would be the next best thing for me. Anyone know of a used one for sale?
    ____________________________
    98 Red GTS
  2. #2
    Join Date
    Oct 2008
    Dutchess County NY
    Default Re: KWIKLIFT Closed
    Hey Max,, believe it or not,, check "Craigs list",, I bought 1 and found it there. good luck
  3. #3
    Join Date
    Apr 2010
    Get a midrise for a little more, you wont look back
  4. #4
    Join Date
    Aug 2007
    Ontario Canada
    Thumbs up Re: KWIKLIFT Closed
  5. #5
    Join Date
    Oct 2000
    Langhorne, PA USA
    Jay...you do realize that the link you've listed shows a mid-rize that picks the car up by the floor?
    I have a mid-rise from Greg Smith that'll lift about 50" and has arms that allow the pads to be placed where they belong.
    It's also moveable, plugs into 120v, and I park my daily driver over it.
  6. #6
    Join Date
    Jan 2008
    southern ,WI
    Quote Originally Posted by Matt M, PA View Post
    Do you know what the collapsed height is? Could a Viper drive over it?
  7. #7
    Join Date
    Aug 2007
    Ontario Canada
    I believe they supply pucks ,if not you can use your own Pucks / pads to access the frame pick up points . Thus the floor pan will not be touched .
  8. #8
    Join Date
    Aug 2007
    Ontario Canada
    Collapsed hieght is 4" ,1/2 " gap when parked , some people sink them 2 "to 4 "in the floor , or use a 2 x 12 to raise your car .
  9. #9
    Join Date
    Oct 2010
    Vincennes IN
    I have an 8.5 foot ceiling and I got a MaxJax and am very happy with it. I use in inside for the Viper and outside for my truck and other taller cars,
    barely but it goes under my Viper. and store it in the corner when I am not using it, it's easy to set up and easier than getting out the jacks, blocks, and jack-stands I used to use.
  10. #10
    Midsouth
    Chuck 98 RT/10's Avatar
    Join Date
    Oct 2000
    tampa, fl USA
    That's too bad. I thought those Kwiklifts were nice units. A little pricey though.
    Chuck 98 RT/10
    BabelMotorsports.net
    SAFEMotorsports.com
  11. #11
    Join Date
    Oct 2000
    Langhorne, PA USA
    OPENRUP....in case you were asking about my lift...which is a TD6MR.
    Lowered, it's about 5.5 - 5.75" total. I do have 2x12s on either side or the Viper doesn't clear. It lifts about 50" with several safety stop positions.
    I bought this lift (as did friends who have a body shop) at the Greg Smith store in DE, and we've both been pleased. I use mine alot, and as mentioned before, park my
    It's also helpful that it can be moved fairly easily. The power unit with the hydraulics is sort of like a hand truck. It has a pin that engages a hole on the lift to roll the lift around...should you want to move it.
  12. #12
    Join Date
    Nov 2007
    Greenwood Village, CO
    Quote Originally Posted by jwolf View Post
    Ok, that doesn't look safe outside with the truck. Do you have some kind of bolt system in your driveway or do you just hope the thing doesn't fall over?
  13. #13
    Join Date
    Oct 2010
    Vincennes IN
    The lift is held down with 10 (5 on each side) 5 inch long x 7/8 flush mount anchors, ($15 each from Maxjax, $8 from Fastenal.) I just bought an extra set. The lift is very stable this was the first time I lifted the truck and it was set a little back heavy, now that I know where to center it's more level. Lift has a 6000 lb limit so the truck in no problem. One side makes a great Motorcycle lift.
  14. #14
    Join Date
    Jan 2008
    southern ,WI
    Thanks for the info and picture Matt! You don't have a picture of the Viper up on it do you by chance?
  15. #15
    Join Date
    Oct 2000
    Langhorne, PA USA
    It's not a great pic....but here's one with the Viper.
    And my Lincoln.....
  16. #16
    Join Date
    Nov 2010
    Southwest FL
    Yep, sucks but those guys did not run a tight ship at all I'm sorry to say. I wanted one forever and finally found one used. I love it, I basically store my car on top of it b/c it is so easy to use. I like that it is mechanical and simple so nothing to fail, but I'm so paranoid I still put jackstands under all the bases lol. I'm having it re-powdercoated this summer the color I want, yellow was the only one I could find, yuck lol This was a picture I took the first time I got it setup and the car on it.
  17. #17
    Join Date
    Dec 2011
    Indy
    Age
    56
    [QUOTE=cfiiman;3048500]Yep, sucks but those guys did not run a tight ship at all I'm sorry to say. I wanted one forever and finally found one used. I love it, I basically store my car on top of it b/c it is so easy to use. I like that it is mechanical and simple so nothing to fail, but I'm so paranoid I still put jackstands under all the bases lol. I'm having it re-powdercoated this summer the color I want, yellow was the only one I could find, yuck lol This was a picture I took the first time I got it setup and the car on it.
    Looks good! I've called on every ad that is within 12 hours of me and they are all sold. Hopefully one will come up for sale soon.
    Brent
  18. #18
    Join Date
    Nov 2010
    Southwest FL
    I didn't think about this but I wonder if their used value will go up since they are closed
  19. #19
    Join Date
    Apr 2011
    Raleigh, NC
    Quote Originally Posted by cfiiman View Post
    What about servicing these units? Who has spare parts?
  20. #20
    Join Date
    Aug 2008
  21. #21
    Join Date
    Oct 2000
    Langhorne, PA USA
    I hate to see any firm close. I can;t asy I'm shocked about KwikLift, though. I though there were incredibly overpriced for what they were.
  22. #22
    Northeast
    Mopar Steve's Avatar
    Join Date
    Oct 2000
    Newark DE
    Quote Originally Posted by CEJ View Post
    There are no serviceable parts. Just steel plates and a manual slide pin. I had one of these and sold it fairly quickly, more trouble than it was worth.
  23. #23
    Join Date
    Nov 2010
    Southwest FL
    Quote Originally Posted by Mopar Steve View Post
    I whole-heartily disagree sir
  24. #24
    Join Date
    Mar 2011
    Mooresville In
    I filed a complaint with BBB against Complete Hydraulics because they took my money for six weeks and did not deliver a lift I ordered. Just fyi
  25. #25
    Northeast
    Join Date
    Oct 2000
    Newark DE
    Disagree with what part? Non serviceability or just being overpriced long steel ramps? I know not everyone has the room for a full size lift, but these are (were) very expensive for the practicality. Sadly the market agreed such that they are no longer fighting the battle.
  26. #26
    Northeast
    Join Date
    Oct 2000
    Newark DE
    Also to this manufacturers dismay, this is more press than they ever got while in business!
  27. #27
    Join Date
    Nov 2010
    Southwest FL
    The part where you said it was more trouble then it was worth, that's all. I'm in agreement they were overpriced and I would never have bought one new, but you can find a used one if you look a while for <900 that is a great deal IMO.
  28. #28
    Join Date
    Nov 2010
    Southwest FL
    Quote Originally Posted by happy56 View Post
    Hey Happy, did you ever get your hood polished out to match AJ's square he did lol
  29. #29
    Join Date
    Mar 2011
    Mooresville In
    nope too busy, but it will be on the market shortly as I am looking for black or dark blue 96-02 gts coupe. Cash is ready if you know one around. Momma sees no humor in the open car.
  30. #30
    Join Date
    Mar 2011
    Mooresville In
    you want to finish the detailing?
  1. Kwiklift
    By SuperBird4404BBL in forum Driven
    Last Post: 02-04-2008, 05:34 PM
  2. Kwiklift Owners
    By ASPIRATIONS in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 05-09-2007, 10:05 PM
  3. Anybody have a KwikLift?
    By agentf1 in forum RT/10 and GTS Discussions
    Last Post: 03-16-2007, 02:14 PM
  4. Kwiklift again
    By Viablo in forum Archive Management
    Last Post: 05-03-2001, 08:34 PM
Tags for this Thread
View Tag Cloud
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
