Click Here!
Thread: Aquamist water meth injection system
Reply to Thread
Results 1 to 5 of 5
  1. #1
    Ohio
    Nadine UK GTS's Avatar
    Join Date
    Oct 2000
    Bath, Somerset, UK
    Default Aquamist water meth injection system
    For years I've run Aquamist water injection (with meth) on my Roe Supercharged '97 Viper (9.8 sec 1/4 on DOT radials and 205 mph standing mile) street car. There's also 3 other SC Viper members in the UK with the Aquamist systems. I found when tuning it on the dyno, the boosted Viper engines really did well with the water, especially on the twin-screw set up with no efficient inter-cooling means. I ran it to almost put the spark out!! The real benefit is with inter-cylinder cooling / anti detonation benefits, but I also saw intake temps drop as much as 80 deg C with the water when measuring on the dyno. With these results I'm able to warm the engine up to temperature pre race run, and then cool with Aquamist on a manual selection function Aquamist developed for me. Anyway, they've just come out with a new updated system, as always looks pretty good, so I thought I post a link up here for those interested in this kind of stuff:
    http://www.aquamist.co.uk/vbulletin/...ead.php?t=2158
    Love is...a Dodge Viper.
  2. #2
    Northern California
    rw99's Avatar
    Join Date
    Dec 2010
    Castro Valley, CA
    Default Re: Aquamist water meth injection system
    Nadine, am I reading correctly that you've used your system to cool the intake prior to staging, but NOT sprayed during the actual run? Basically using a "purge" switch or similar manual spray switch?
    I've got a turbo car with a fully boost-referenced MeOH system (AlkyControl), but it's tuned for it. Now I'm considering adding a methanol/water system to another (blown) car purely to manage heat soak at the drags... just a simple, manual spray to cool off the intake, maybe both after a run and before the next run. Thoughts?
    I highly recommend a quality meth system for anyone using forced induction. Multiple benefits include serious reduction in IATs and effective octane increase...
    Rich
    '09 ACR
    Driving the dream
  3. #3
    Ohio
    Join Date
    Oct 2000
    Bath, Somerset, UK
    Yes to manage heat soak, purged pre staging, using a varible control switch mounted within reach, you need it varible as on tick over rpm you dont want to flood it, you can hear it start to try to stumble if you spray too much as it cools, also it gets richer with the meth, and the PCM will start to try to trim it back after a while! I then let the Aquamist system active mapping manage the spray during the run.
  4. #4
    Join Date
    Dec 2005
    Harford county MD
    Thanks for the link!
  5. #5
    On a high cr N/A engine (say 14:1) would you be able to run 92 pump gas with the w/m system?
  1. Water/Meth Injection System Pics
    By litemup in forum Performance Modifications
    Last Post: 04-10-2009, 01:46 PM
  2. Water/meth injection...
    By X vetter in forum RT/10 and GTS Discussions
    Last Post: 04-29-2007, 08:43 AM
  3. Roe water/meth injection...
    Last Post: 09-01-2006, 07:36 PM
  4. Water / Meth injection question for S/C
    By King RT10 in forum RT/10 and GTS Discussions
    Last Post: 02-21-2006, 05:32 PM
  5. I Want My MIS ( Meth /Water Injection System)
    By 00prowler in forum RT/10 and GTS Discussions
    Last Post: 01-30-2005, 01:05 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
