help with Oil pressure gauge drops to zero
c65491
so ive done my research before i post here.
my problem happened a month ago, basically the Oil pressure gauge falls to 0 and come back up again .it does that more than once, and keep doing while driving normally
it happens after WOT sometimes and sometimes when the car warms up and just idling ,
the car pulls as hard as ever, no strange noises in the engine
2008 coupe 20k miles
thanks in advance
swexlin
West Chester, PA
Bad sender, most likely. My 97 Ram (also a V10 by the way!) had this same symptom, and that's what it was. However, just to be safe, DO NOT drive it - get it towed to the dealer, and have them check it. Better safe than sorry.
C
c65491
what do you mean a bad sender , could you explain that more. thank you very much for your response
bluesrt
sender is what detects the oil pressure and transends it to your guage,they go bad alot with all cars,very cheap fix usually. good thing is if you have no top end tapp noise or any other noises,its just that- i bet 20 bucks it is. especially if its bouncing around like that,usually oil pumps fail and stay failed, dont come and go(usually)
Silver04
San Antonio, TX
Happened on my Vette years ago and it scared the crud outta me...they replaced the sender and oil pump, I do believe, under warranty. Good luck!
