Thread: Why can't I post in the VCA regional sections?
Reply to Thread
Results 1 to 7 of 7
  1. #1
    Venomiss
    Guest
    Default Why can't I post in the VCA regional sections?
    The VCA Regional area only allows current Viper Club of America members to post.
    To join the VCA as a brand new member online go here. Memberships run from January 1st to December 31st each year. $115 for Standard and $150 for Venom
    https://www.viperclub.org/join/
    If you were a VCA member in the past and wish to renew for 2012 go to the VCA Membership Portal.
    Members who renew by December 10th online only will be eligible for (3) Visa gift cards giveaway donated by Viper Parts of America.
    https://www.viperclub.org/membership/
    Detailed instructions on how to use the VCA Membership Portal is here.
    http://forums.viperclub.org/threads/...n-Instructions
    For questions contact the VCA at [email protected]
  2. #2
    Venomiss
    Guest
    Default Re: Why can't I post in the VCA regional sections?
    If you are a VCA member and your Venom tag is not showing or your access is not turned on please read here.
    http://forums.viperclub.org/threads/...sing-Venom-tag
  3. #3
    Venomiss
    Guest
    Just a friendly reminder if you have not renewed your VCA membership for 2012......Spring is just around the corner.
  4. #4
    Join Date
    Nov 2009
    Houston, Texas
    I just joined but cant post in my region. Any idea on who I should contact? I think I recall reading it somewhere
  5. #5
    Venomiss
    Guest
    Quote Originally Posted by killerviper View Post
    Please read the links in the previous posts and this checklist below to get you rolling.
    VCA Member, but cannot see the full forums or missing Venom tag
    If you are a current VCA member, or a VCA Venom member and cannot view the full forums, here is how to fix that:
    1. Click "Settings" in the upper right hand corner, then click "Edit Profile".
    2. Enter your 5 digit VCA membership number there. If your VCA membership number is 345, enter 00345. If you do not know your membership number, check your name badges, or call VCA HQ for assistance.
    3. Visit the VCA membership portal at https://www.viperclub.org/membership/ and login. If you have not been there before, you will need to request a new password. Simply click the link provided and follow the directions.
    4. Once logged in, scroll to the bottom of the page, and enter your forums username and then click "Update forums". If you're a venom member, you may also select your forum badge there.
    5. If you are an officer, you will need to ensure that the email address used in the forums is the EXACT same email address used in the VCA Membership Portal. If it does not match, you will not have the access that you should have.
    Once you have completed these steps, you should have all of the correct access to the forums.
  6. #6
    Join Date
    Nov 2009
    Houston, Texas
    Thanks Venomiss, worked like a charm
  7. #7
    Venomiss
    Guest
    Fantastic and thank you for joining the VCA Houston Region!
  1. Regional post?
    By viciousone in forum Board and Site Questions/Suggestions
    Last Post: 12-03-2010, 12:50 AM
  2. can't post on Regional Forums
    By diko in forum Board and Site Questions/Suggestions
    Last Post: 02-24-2010, 11:02 AM
  3. Rendevouz caravan from MI, see regional event section post.
    By RoyV101621 in forum RT/10 and GTS Discussions
    Last Post: 08-02-2001, 11:30 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
