Thread: extra coolant reservoir ?
Reply to Thread
Results 1 to 11 of 11
  1. #1
    Join Date
    Aug 2007
    Alberta Canada
    Default extra coolant reservoir ?
    i just pulled the front plastic off my 94 and discovered
    another coolant reservoir. is this the overflow catch or an extra
    pot? if it is the overflow why does it have the min max lines and
    a fill cap?
    Shane Crompton
  2. #2
    Great Lakes
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    Default Re: extra coolant reservoir ?
    It is an overflow bottle from the neck of the pressure bottle. It should be filled to halfway between the two marks when COLD, using a small funnel placed into the hose that one pulls off of the neck of the above mentioned pressure bottle (the one with the "radiator cap").
    I don't do "PM's" and I NEVER read "visitor messages" since I prefer DIRECT communication.
  3. #3
    Join Date
    May 2012
    Quote Originally Posted by Crompton View Post
    a fill cap?
    Shane Crompton
    I just found this out myself. Strange place to put it.
  4. #4
    Great Lakes
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    Remember this recent post:
    http://forums.viperclub.org/threads/...n-garage-floor
    In which I stated:
    "Big Dog, I find it most helpful to check the coolant level in both the pressure bottle under the hood and the overflow bottle in the nose before and after each use if you are only driving said Viper occasionally. If you are able to drive it regularly, then I would suggest that you check these things weekly as this cooling system has its own quirks...and, this can be a costly arena if neglected. I have met literally dozens of Gen I and II long term Viper owners ( and one self proclaimed "viper tech") who had no idea there was a bottle in the nose...let alone how it functions or should be inspected and/or serviced. Many of us have had to learn this the hard way."
  5. #5
    Join Date
    Jun 2008
    Littleton, CO
    Here is another good thread to read. Dave explains how that coolant recovery bottle works within the Cooling System...
    Easy way to check coolant?
    Here is the diagram out of my 2001 Service Manual...
  6. #6
    Join Date
    Aug 2007
    Rocky View County, Alberta
    not to hijack... but paint job time Shane??
  7. #7
    Join Date
    Aug 2005
    Chandler AZ
    The posts above tell it all. (But I will add my two cents anyway.)
    The pressure bottle in the engine compartment is really only a place that the designers could fit the pressure control cap up high in the system since the radiator is very low and inaccessible The tank in the front bumper cover is extremely important for the operation of the system. It is not technically an "overflow" tank. It is part of the normally operating system where the expanded fluid goes to and comes back from when the system gets hot enough to open the pressure valve in the cap.
  8. #8
    Join Date
    Dec 2011
    Indy
    Age
    57
    Make sure the tank with the pressure cap is completely full.
  9. #9
    Join Date
    Aug 2007
    Alberta Canada
    Quote Originally Posted by All Blue ACR View Post
    just the front for now. it's hurting bad and needs the most work.
  10. #10
    Join Date
    Jul 2007
    "Discovered" this tank. LOL @ Dodge for letting this happen. I mean, read the owner's manual and see if you get the full picture on the Gen 1 / 2 cooling system.
    Like I've said a bazillion times, that tank and the line to it, along with an appropriate level in said tank, are critical for keeping air out of the system. If you have an air bubble in your surge tank on the fenderwell all the time, then this tank is probably not working like it should.
  11. #11
    Join Date
    Jan 2012
    I had this problem a month back my overflow bottle was cracked thanks to Steve-Indy who told me wher it was. I did not want to pull the front facia to replace so I purchased a overflow bottle from Advanced Auto and mounted it under the power brake booster and plumbed it in the system. Its so easy to see and service and solved my leakage and cooling problem
  1. P/S fluid reservoir cap
    By orsini112 in forum What'cha Need for Your Snake?
    Last Post: 05-19-2009, 09:12 PM
  2. Extra! Extra 85 Year old Grandma Drives New Viper Coupe
    By VipeRicK in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 10-07-2005, 10:18 PM
  3. HOLY COW!!!!!!!!!!!!!! EXTRA EXTRA READ ALL ABOUT IT
    By steve911 in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 09-07-2005, 02:36 AM
  4. EXTRA! EXTRA! Spiderman Viper Pics Right Here
    By Scott J in forum RT/10 and GTS Discussions
    Last Post: 06-17-2002, 01:30 AM
  5. EXTRA! EXTRA! Spiderman Viper Pics Right Here
    By Scott J in forum Sneaky Pete's Place
    Last Post: 05-02-2002, 02:30 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
