Thread: Installed New Pedals
Reply to Thread
Results 1 to 20 of 20
  1. #1
    Join Date
    Apr 2011
    Miami, FL
    Default Installed New Pedals
    So I've been wanting to upgrade the pedals on the car but could not find anything decent. So during my search I came across a company that made Porsche pedals. When I called him to see if we could do something custom he tells me he was a Viper owner in the past and had some designs done for them! Even better he had a set for the GTS done! The company is SRP Racing. They are machined in the USA by them. Great pedals!
    I got the following set. The brake and clutch are identical with an aggressive pattern on the tread. It is impossible to slip off the pedals. The accelerator is dead smooth with the heel/toe extension. The smooth finish lets you slide your foot on the accelerator pedal. A some for heel / toe driving. While I have not tracked the car, I can tell you it was awesome to drive on mountain roads in Virginia.
    The pedals...
    The pedal surface detail. The nibs are very sharp and they work perfectly to eliminate all slippage concerns.
    Not going to get into a huge amount of detail but let's just say I took a great deal of care to get alignment perfect. I did it with bright masking tape so I could see it through the pedal's holes. I then clamped the pedals in place. From there I marked (with a punch) and drilled a pilot hole on the brake and clutch. I then drilled the hole to the required size and bolted them in place. On the accelerator I aligned and drilled pilot holes for the screws (wood screws provided). I then placed two face molding tape on the pedal and then screwed it down. Between the tape and screws, it's not moving.
    This is a shot showing how I used the tape.
    Below is the shot of the installed pedals..
  2. #2
    Join Date
    Oct 2012
    East Hanover, NJ
    Default Re: Installed New Pedals
    Very cool... Thanks for sharing! I like the design and the smooth gas peddle. How much?
  3. #3
    Join Date
    Apr 2011
    Miami, FL
    The pedals ran about $120 shipped. Until just recently, the other pedals I had been looking at where made by Ultimate Pedals. They just dropped their prices. They used to be in the $200 range. Now I guess the volume has dropped off and so have prices. When I bought these I was getting a cost over $200.
  4. #4
    Join Date
    Jul 2007
    What type of screws attaches them? I would assume on the brake and clutch they are machine screws with nuts on the back, but what goes in to the plastic gas pedal? And did the location of the screws interfere with the webbing and linkage on the back of the gas pedal? Those do look good.
  5. #5
    Join Date
    Nov 2008
    looks like they attach from sides of pedal with no drilling
  6. #6
    Join Date
    Oct 2007
    DE
    Age
    35
    Very nice looking and fuctional. Good find Luisv. Thanks for posting this thread. Im sure SRP Racing will be thanking you in the future for all the calls they will be getting for Viper pedals. I'll prob order a set if i have some spare cash after the holidays.
  7. #7
    Join Date
    Jul 2007
    Quote Originally Posted by bluesrt View Post
    Umm kaa. Better lay off the shine when posting. This here be the technical area.
  8. #8
    Join Date
    Nov 2008
    looke here 0000 get back to clunker n hush up- and stop asking common sense questions
  9. #9
    Join Date
    May 2012
    Tee he he he ^^^^^ You two!!
    Those pedals look great but I think you need some nicer floor mats to match. The ones you have now look like a bath tub non slip mat. No offense.
  10. #10
    Join Date
    Oct 2010
    Duck Dynasty Back Yard
    These are for a GTS? What's the difference between these & the ones for an RT/10?
  11. #11
    Join Date
    Apr 2011
    Miami, FL
    Quote Originally Posted by dave6666 View Post
    The screws on the accelerator are countersunk wood screws. They are about 3/4 inch long if I recall. The screw right into the plastic but not far enough to bother the linkage and spring behind the pedal. I put some good two face tape behind the pedal as well. Between the thin foam tape and screws it is on there very well.
  12. #12
    Join Date
    Apr 2011
    Miami, FL
    Quote Originally Posted by mattdillon View Post
    There is none. I simply mention the GTS b/c it's my car. Pedals are the same.
  13. #13
    Join Date
    Jul 2007
    Quote Originally Posted by Luisv View Post
    Well blu, who's the smart one now?
    Anyway, thanks to the OP for the reply / explanation. The double sided tape is a great idea. I have some 2" wide stuff laying around so I'm all set.
  14. #14
    Join Date
    Nov 2008
    you seem to be the winner!!!!! wich trailer park do you want me to send you your trophy?
  15. #15
    Join Date
    Jul 2007
    One that has no grammar or spelling rules would get you in.
  16. #16
    Join Date
    Nov 2008
    Default lol.............
    Lol.........
  17. #17
    Join Date
    May 2012
    Wood screws and double sided tape? With some of you guys with duck feet somehow I don't think it will stay put!
  18. #18
    Join Date
    Apr 2003
    Spring, Texas
    Be glad the Gen 2 had somewhat decent pedal spacing for proper heel toeing at the track as the Gen 4 really lacks this. The pedals are too close. Lets hope they get it right in the new model. Mazda and Lotus are a perfect example of how they should be.
  19. #19
    Join Date
    Jul 2007
    Quote Originally Posted by Sybil TF View Post
    Wood screws and double sided tape? That's exactly how I would have done it, but I'm no smarter than a duck!
    TommyFox. Whaddup.
  20. #20
    Join Date
    May 2012
    TommyFox. Whaddup.
    Te he he. Say hello to the the Finster for me!!!
  1. Has anyone installed adjustable pedals in a Gen I?
    By 488viper in forum RT/10 and GTS Discussions
    Last Post: 03-01-2012, 10:33 PM
  2. Gen II Pedals
    By Steve 02/RT10 in forum RT/10 and GTS Discussions
    Last Post: 06-06-2005, 04:09 PM
  3. Autovation pedals installed
    By Vic in forum RT/10 and GTS Discussions
    Last Post: 03-27-2003, 02:02 PM
  4. New Pedals Installed (pict)
    By Anthony - 98 GTS in forum RT/10 and GTS Discussions
    Last Post: 04-09-2002, 06:40 AM
  5. SRT-1O pedals??
    By Tom Friend in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 03-22-2002, 09:09 AM
Tags for this Thread
View Tag Cloud
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
