Thread: OEM 6 Spoke Wheel Alloy / Composition?
Reply to Thread
Results 1 to 6 of 6
  1. #1
    Join Date
    Apr 2012
    Indianapolis
    Default OEM 6 Spoke Wheel Alloy / Composition?
    To Quote Nine Ball in this thread:
    http://forums.viperclub.org/threads/...D+WHEEL+WEIGHT
    Quote Originally Posted by Nine Ball View Post
    The only "lightweight" factory Viper wheels are these, which are rotary forged barrels with cast aluminum spokes.
    Copperhead Edition 5-spokes
    Gen 4 ACR 5-spokes (same wheel as above)
    Gen 4 6-spokes
    The rest of the factory wheels are sort of heavy.
    The factory wheels have cast aluminum spokes and rotary forged barrels...
    Does anyone know the actual alloy used for the wheels? Is the alloy consistent between the spokes and barrel?
    Thanks!
  2. #2
    Join Date
    Aug 2007
    Houston, TX
    Default Re: OEM 6 Spoke Wheel Alloy / Composition?
    The wheels are 1-piece, with the same alloy used throughout the wheel. Rotary forging is a process done to the cast aluminum preform, where it is drawn over a hot mandrel to create the final shape of the barrel. The heat and pressure used to do this process helps align the grain structure and makes the wheel stronger. This means they can use a thinner material thickness, which results in a lighter wheel barrel.
    Video of process: http://www.youtube.com/watch?v=-kyU-SxePIY
  3. #3
    South
    gb66gth's Avatar
    Join Date
    Dec 2007
    Big-D
    That's friggin cool!
    Is it weird that I'm mildly aroused?
    '05 Black SRT10 vert.
    '08 Black SRT10 vert.
    '66 Shelby GT350H "Rent-A-Racer"
  4. #4
    Join Date
    Aug 2007
    Ontario Canada
    Great video , thanks for sharing !
  5. #5
    Join Date
    Apr 2012
    Indianapolis
    Good information. So do these wheels have the same properties as a forged wheel when it comes to heat treating? I know many have powder coated their OEM wheels - is heat cycling a concern or not since it is not really a forged wheel?
  6. #6
    Join Date
    Aug 2007
    Houston, TX
    I'm not a metallurgist by trade, but I do deal with a lot of materials issues in my career (oil/gas). Powdercoating indeed raises some concern, even on forged wheels. Temperature control and duration are important, as to not alter the structural properties of the aluminum. If you ever powdercoat wheels, make sure it is an experienced shop that knows what the safe limits are.
    Forged wheels are 6061-T6 aluminum alloy. Cast wheels are usually 356-grade aluminum alloy. 6061-T6 Forged wheels are better quality, of course.
  1. Gen 1 Wheel Swap to Gen 3 H-Spoke
    By mmcc269 in forum RT/10 and GTS Discussions
    Last Post: 12-24-2012, 08:24 AM
  2. 5 spoke rear wheel
    By QUICKSRT10/SRT8 in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 06-14-2011, 09:12 PM
  3. 6 spoke wheel pic
    By ferraritoviper in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 08-23-2009, 12:36 PM
  4. need 06 5 spoke wheel
    By Flying Viper in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 05-20-2009, 09:32 AM
  5. need 08 H spoke wheel !!!!
    By PET SNAKE in forum Tire , Wheel, Brake and Suspension
    Last Post: 03-18-2008, 11:06 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
