Thread: EGR Valve off/on status??'
Reply to Thread
Results 1 to 5 of 5
  1. #1
    South Florida
    Join Date
    Dec 2012
    Question EGR Valve off/on status??'
    OK, trying to do my first custom tune with SCT + PRP + INNOVATE O2 WB sensors data logger. How do you know EGR is ON/OFF STATUS in order to modify cells?
    As far as I collected info, modify cells USING WIDEBAND AS DATALOGGER in this order:
    1. With engine at idle.
    2. Crusing, light throttle.
    3. Moderate throttle.
    4. WOT, from 1500 to 6000rpms 3rd gear (if AFR above 12.5 stop!).
    So again, How do I know which EGR OFF or ON cells to modify in each of above 4 scenarios?
  2. #2
    Join Date
    Sep 2003
    Cottage Grove, Wi.
    Default Re: EGR Valve off/on status??'
    The Viper motor does not have an EGR valve.
  3. #3
    South Florida
    Join Date
    Dec 2012
    I understand EGR OFF/ONN cells are used in SCT Pro Racer software to tune the car.
    Maybe not found as EGR valve under Mopar parts, but it seems this is it:
    http://www.moparpartsoverstock.com/p...4669475AB.html
    Anyway, there are two map tables (EGR ON/OFF) which are used to change AFR ratio in order to fine tune Vipers.
    Quote Originally Posted by steve911 View Post
  4. #4
    Join Date
    Mar 2011
    Sonoma Cownty
    The duty cycle purge solenoid has nothing to do with Exhaust Gas Recirculation-- it's job is to take fumes from the fuel system that collect in the charcoal cannister and 'purge' the canister of fumes by letting them get drawn into the engine. I suppose the tuning map could compensate for the solenoid on Vs. off state, but it would be a small compensation. Does anyone know what operating conditions open the purge valve?
  5. #5
    South Florida
    Join Date
    Dec 2012
    This is a SCT PRP software window. There are two tables with cells in order to add or substract fuel: EGR OFF and EGR ON, this pic displays EGR OFF table. After reading Steve as Sonoman posts, there's NO EGR valve. So I am going to do some testing in order to find out which table is the one to consider for tuning my car.
    So my first asumption there was an EGR valve is WRONG.
    Thanks!
  1. Expansion Valve ("H-valve") is stuck. AC is blowing warm air
    By mendler23 in forum North & South Carolina
    Last Post: 06-05-2012, 05:03 PM
  2. valve to head contact question and 2.02 and 1.6 valve heigth
    By mrbob in forum Performance Modifications
    Last Post: 11-20-2011, 10:32 PM
  3. bypass valve vs blow off valve...
    By 97snk in forum RT/10 and GTS Discussions
    Last Post: 11-26-2010, 01:49 PM
  4. Difference in Blow off Valve vs. By Pass Valve.
    By Qualitywires.com in forum RT/10 and GTS Discussions
    Last Post: 02-25-2005, 12:03 AM
  5. Brake proportioning valve delete/new valve installation
    By NDW in forum RT/10 and GTS Discussions
    Last Post: 05-17-2004, 11:40 PM
Tags for this Thread
View Tag Cloud
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
